experimenting with that wanna be glow!
Viewing 3 reply threads
    • #12185
      ph2t
      Excess old computer parts can come in handy. What you see below is a piece of plastic that was used by old hardrives to shine a LED indicator through a front panel. So the good thing here is that this plastic is suited to carry light, so to speak.
      So what I did was get a small SMD blue led and glued it to the end of one of the pieces. Here you can see it mounted at the end.
      Now, putting 3V though it gets OK(but not great) results:
      In semi-strong light:
      As you can see, not very bright.
      In a darker environment:
      It really needs to be dark to see the effect well.
      But, putting 6V through the blue led show a much stonger effect.
      As you can see, there s still some definition in the light pattern coming from the clear plastic rod.
      Now it rocks!
      More experimentation to continue, more to come!
    • #52244
      jamiekulhanek
      wow! neon tube! sick!
    • #52245
      z-beam
      that is awesome! have you come across the ultra violet led’s yet? i have two in keychains that flourese some minerals i have that contain phosphor. that and any flouro coloured plastic…
      you’ve seen the monster over at bitpimps havent you?
    • #52247
      merc-blue
      if you want a cheap and easy way just go and buy some EL wire from jaycar
