firelap out of control
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › firelap out of control
- This topic has 8 replies, 3 voices, and was last updated 20 years ago by
woosh_x.
February 3, 2006 at 6:07 am #12514
hi all I have a firelap 02 fully hopped ie
sipder turbo
x-speed pro
iwaver alloy everythingnow the proublem is now with all the alloys installed , as soon as i pull the trigger the car turns left, Think it’s the ball diff, iv’e adjusted it every way i can, packed it with grease, ran it dry etc. I either have it kicking to the left or just spinning the cog while the car just sits there.
any ideas on this one??? is all the alloy tomuch weight? should i go to the old diff?
where the big proublem is, when i start the car moving i have to keep the wheels turned right, just enough to deal with it’s lust with left (tougue steer i guess), once at 1/2 and 3/4 speed she is fine, but when at full speed she will kick to the left again and do a little spin! the car just loves the left.
ps. it not the trim due to the fact when rolling or with out acceleration it goe stright!
pss. i have the same result using a super x-speed.
February 3, 2006 at 6:51 am #58183
more news on the above when i pull the trigger the wheels turn to the left a little by them self but when the trigger is at idle the wheels are normal
February 3, 2006 at 7:56 am #58128
have you tried adjusting the POTS dial on the pcb….it alters the steering signals…maybe it might help. learn more before you mess with it. check on this link: http://www.mini-z.be/pcb.htm
February 5, 2006 at 7:57 am #58063
Swap out the diff. It takes like two seconds. If it’s not that, then check your spider connections. You may have shorted something out.
February 6, 2006 at 2:59 am #58050
Cheers all
It’s the diff I put the old one back in and all is cool
February 7, 2006 at 2:30 am #44036
On that diff that you had, who made it? I was thinking about the little screw thing (can’t think of the name right now). If that comes loose or falls out you can get symptoms like this. It will pull to the left because the left tire is getting no power and the right tire is getting power, so it turns like it has tank steering. It will sometimes go straight, but will never stay straight for long.
I added some screw tightener/gap filler to help keep it in place. I even took it a step further and put a small dab of super glue on it. I noticed all my ball diffs having the same problem. Check that little tiny half screw.
It’s worth the effort. A ball diff is much better than a gear diff.
February 7, 2006 at 4:01 am #44034
iwaver made this one, I got one ot the 10 in one alloy kits from toyeast.
all works pretty good but adds a lot of weight. Plus the diff is a bit of a no go.I also had to re-drill the alloy front Steering Knuckles so the king pin would slide, in fact all the steering parts required a little adjustment ie filing drilling etc. to work correctly.
anyway back to what you were saying
“I added some screw tightener/gap filler to help keep it in place. I even took it a step further and put a small dab of super glue on it. I noticed all my ball diffs having the same problem. Check that little tiny half screw.”
I don’t know what half screw you are talking about, and where did you put the super glue?
February 8, 2006 at 12:11 pm #44031
It’s a small black screw that should have come with your ball diff set. You need a really small allen wrench to screw it in. It would go on the side without the gear on it. I’ll try to get some pictures of what I’m talking about because I can’t really think of the names of everything or describe it very well. It sounds like that is exactly what your problem is.
March 8, 2006 at 10:27 am #44068
This was over a month ago now, but I figure you still might need it or it’s good info for other people. Here’s a few pictures of a ball diff. On the end opposing the gear you have a cylinder piece with a hole in it. There is a small grub screw that goes in that hole. You slip the cylinder piece on the axle and lock it in place with the grub screw.
