GEARS WHINING?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › GEARS WHINING?
- This topic has 14 replies, 4 voices, and was last updated 23 years, 2 months ago by
August 17, 2002 at 4:37 am #9272
My gears on my new supra whine and screech everywhere, if I take the shell off it whines alot less.
should I rub a little lube on the gears?
August 17, 2002 at 10:52 am #15335
what gear setting and motors are you using?
August 17, 2002 at 1:28 pm #15344
I’m using a 2.2 motor and the white gear (on the motor)and orange gear (don’t know the ratio)
I’m new to Bits so I don’t exactly know how to fix the problem
August 17, 2002 at 2:10 pm #15346
Tahts the problem .. you need the BLACK PINION on your motor, not the white, that is for bit racers .. cahnge to the black oneand you should be right !
August 18, 2002 at 4:47 am #15353
I can’t put the black pinion in because itis damaged, I don’t know how. Now my car only whines for a while and then stops, sometimes it’s a whole day before it whines again.
August 18, 2002 at 4:48 am #15354
The white one works fine
August 18, 2002 at 5:20 am #15355
the white pinion gear may work fine but it is not meant for use with the bit char-g, the white gear are to be used on bit racer. using the black gear should solve your problem….hope that helps.
August 18, 2002 at 5:39 am #15356
my black pinion is damaged
August 18, 2002 at 8:24 am #15360
what part of this dont you understand the white gear is the one that s screwing up your bit get a new black gear unless you want a screwed up car
August 18, 2002 at 10:28 am #15362
Hey I’m a newbie, how am i supposed to know that it’s gonna stuff up my car? I’ve had it for 2 days!
August 18, 2002 at 10:42 am #15364
silversupra if you want to get a new black gear, there are plenty of ’em on ebay, i believe they come with the micro b 3.0 motor.
August 18, 2002 at 2:16 pm #15368
are u sure?
August 18, 2002 at 5:40 pm #15372
Yes they do come with a black + white pinion.
quite sure.
August 19, 2002 at 8:57 am #15385
The black pinion comes in the gear set too. I think that the kit comes with 2 or 3 black pinions .
You really need the black pinion on your motor.
Good luck
August 19, 2002 at 11:41 am #15389
smile everyone!!!
