GPM MZ352
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › GPM MZ352
- This topic has 4 replies, 3 voices, and was last updated 21 years ago by
January 10, 2005 at 1:42 am #12497
Hi everyone, i got me some of these new beaut shocks. Problem is i can t work out exactly what s meant ot go where. And the good folk at GPM decided to not included fitting instrucions. There s little aluminium washers etc. Hopefully someone has either fitted these, or know where i might be able to find instructions (i ve been looking on the net for 2 hours already)
Thanks
PS here s a weblink for the shocks
http://www.hobbyetc.com/cgi-bin/item.cgi?part_id=6099&car_id=80
January 10, 2005 at 6:48 am #57898
YOU CAN DO IT !!!
January 11, 2005 at 11:09 pm #57943
…Not exactly the reply I was expecting. But i’ll play along. How do you know I can do it unless you’ve done this yourself or seen someone else do it? And on that note, how did this person come about to find the information explaining how to fit these? There was no fitting instructions with mine and I have searched the internet for information eplaining how to fit them.
January 12, 2005 at 12:27 am #57944
Hey there Hype
It cant be much diffrent from the brands that ive delt with, but dose look alittle different.
At the time of my you can do it comment i’d had a few to many to drink….The picture shows the springs already set up, So the bottom is the silver part with the 4 screw holes, &, It looks to me that you would mount that black T peice with 2 holes on the top of the car (chassis) to line up with the screws at the top of your suspension peice,
Mounting that T peice and those 2 washer type spacer things then screws to secure, The other screws you can work out for yourself but the 2 longest one’s are for the bottom part nearest the motor mount side beetween the MM & the H plate…My instructions may not be clear, also, I dont know if its for 01 Or 02…
Look And compare the picture to what im saying and it should all slide into place…
The pict shows the layout basically, its all there…All you have to do is fit it but whats on the left (the black plastic peice) screws on in the direction you see it all layed out and then fits on to your car the way its all then sitting
is another way to explain it…Is this any Help buddy.
Cheers peteWaw
January 12, 2005 at 1:41 am #57946
my advice is to look at pics of cars with the shocks installed:8ball:
