How Do You Drift?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › How Do You Drift?
- This topic has 31 replies, 13 voices, and was last updated 22 years, 5 months ago by
Mut1ey.
September 21, 2003 at 9:47 am #11366
I’ve tried many times with my bit but after so many tries, I still can’t drft. Does anyone out there know how?
September 21, 2003 at 11:10 am #39287
go out b n buy a digi qr (or normal digi q) n them buy the special contorler (the one with the lcd screed in it)
September 21, 2003 at 1:26 pm #33193
Get your car fet modded.:D
September 21, 2003 at 1:52 pm #33194
LOL nice work uA i rekon if u get fetted get the biggest as it is fastest;.. also peopel have been known to cover there tyres with eletrical tape
September 21, 2003 at 2:57 pm #33195
I have never seen a bit drift…
I have seen them slide and spinout but never ever drift. But the mosfet mod will help fo sho on your quest(hey micro amp think you could mosfet my digi q tank? hehe)
September 21, 2003 at 7:20 pm #33019
I’ve heard of putting tape on the rear wheels tomake them less tractiony… but what if I just paint them? That way, I can choose colours and also just repaint it if the paint gets rubbed off
September 21, 2003 at 8:19 pm #32990
I think the principle with drifing is not making the rear tyres have less traction but increasing the inertia of you car so that when you do turn the car resists and sort of “strafes” off to one side. I dunno, new to the whole car thing be it 1/64 or 1/1 scale.
Check out my investigation going on here:
http://www.ausmicro.com/link.asp?TOPIC_ID=1239ph2t.
September 22, 2003 at 3:19 am #39282
You have to have soft microsizer tires on the rear and hard tires on the front. It works with medium rear tires too.
I just use my Zip Zaps SE with all season tires or sport tires
September 22, 2003 at 3:40 am #32955
One of my Dual Cell car can drift. It has stock tire on. it has a broken circuit(forward) so it goes same speed forward as a single Bit but has more torque. the tires got dust on it after play with it for a short time. then because it’s an external dual cell.the rear wheels got dust so it doesn’t have alot of traction so the rear been thrown out more than usual but not enough to let the car spin out. so all i have to is press the opposite direction to let it get back straight. and it can do does slidding donuts with a radius of about 30-50cm.
I will take a video of it once i can borrow a Digi Cam of my friend. -
September 22, 2003 at 12:48 pm #32952
thanks a lot. I wnat to be able to drift my microsizer but I don’t want to spend alot of time modding or changing my car. Will a 2.2 motor work for drifting?
September 22, 2003 at 1:12 pm #32953
You can’t expect something from nothing. You need to put the time in to mod to get what you want out of it. A 2.2 prolly won’t work.
September 22, 2003 at 1:26 pm #32954Quote:thanks a lot. I wnat to be able to drift my microsizer but I don’t want to spend alot of time modding or changing my car. Will a 2.2 motor work for drifting?
Yea if you wanna get anykind of drifting(or as goodd as a bit can really drift) you need to keep changing parts adding mods till you have what you are looking for.
You also have to remember that every car is different. One person might havea car set the way it runs good on there track but move it to a different surface and that car is done.
So take the basics of drifting you need speed and power along with good controll and the chassie has to be weighted correct(both in rc and rl(real life).
So take all those things and start playing with different combos.
If you want a drifter right out of box then you better go bigger and get mini z or even bigger then that to have any chance of a Out Of Box drifter.
“the funs not all in racing but also in working on the cars”
September 22, 2003 at 6:04 pm #32899
thanks alot. I was, however wonderiing if the chassis (as in the body, shell thing) has anything to do with speed or control?
September 22, 2003 at 6:44 pm #32905
Given its bugger all weight in comparison to the chassis I don’t think so. Not in this context.
September 23, 2003 at 3:22 am #32435
the main part u have to focus on is the tires and the steering if u want to drift. the correct motor is also important.
September 23, 2003 at 4:26 am #32436
Technically, drifting is when all four wheels slide through the corner. This typically only occurs in 4-wheel drive cars, and it’s very difficult to get a 2-wheel drive car in any scale to ‘drift’.
If your just talking about pitching and sliding through corners, I had a MS Sport that did that straight out of the box w/ the 1.6. It actually wasn’t cool, because when I put faster motors in it, it would spin out all the time. I isolated the problem to be the setup on the front suspension, seems the front end was diving too much, and lifting the back wheels too much.
September 23, 2003 at 12:01 pm #39629
Don’t you get a rear axle drift set with the Suspension part set and also the Tune Up car set?
This is basically a solid plastic wheel that you don’t put tyres on, so it slides around more.
Thats my understanding anyway. Anybody tried em?
Mutters
September 23, 2003 at 12:48 pm #32324
well, instead of buying that set, why not just do a mod using the hot wheels wheels and slap them onto and axel? Saves money
September 23, 2003 at 12:50 pm #32325Quote:…….. it would spin out all the time. I isolated the problem to be the setup on the front suspension, seems the front end was diving too much, and lifting the back wheels too much.
Interesting point there dave, I believe you might be onto something. So far I’ve been testing using the standard suspention bar. As you know each wheel compliments the other, one goes up, the other goes down and vice versa, there’s no independant suspention.
I will kill it and put in some stiffer than usual springs to counter the lead plate I have and test it out. I was also thinking of making the lead plate the full length of the car to increase surface friction…
How about using the rear pullback wheels. Would they be suitable for this? help drifting?
Edited by – ph2t on 23 September 2003 08:53:19
September 23, 2003 at 6:33 pm #32270
Throttle control plays a big part, and since bits are all or nothing throttle it makes drifting very hard indeed. Mini Z or bigger is king for drifting, though mini z’s do suffer from torque steer.
September 23, 2003 at 7:13 pm #32275
I own a mini z and it drifted right out of the box. I was hoping for the same with my first bit adn when that didn’t happen, it started modding it and basically broke it in the process. That’s why I don’t really want to mod the car as in the actual chassis that much
September 26, 2003 at 2:41 pm #33380
What I’ve found most for drifting with my bits is that Dust is your friend!!!
On my old track that I have since destroyed, it built a layer of dust up from sitting under the bed. After a lap or two, the dust would build up on the tires, and the car would get some drift action.
I’ve also noticed this driving on Hardwood floors with a little dust buildup.
September 26, 2003 at 6:07 pm #33391
i read somewhere that if you spray paint a track with chalk board spray, you will get good grip. So what if I do that but put a pinch of chalk dust where I want the car to drif… will that work?
September 27, 2003 at 5:07 am #31657
i agree with M coupe. Dust is important on the tires. it’s better to use a stock(med) tire with dust on it instead of hard ribbed tires.
September 27, 2003 at 5:51 am #31490Quote:…it’s better to use a stock(med) tire with dust on it instead of hard ribbed tires. -Leonli17
I’ve got the multicolored hard/med/soft(blue/purple/red) set, so they’re all slicks, but I also got the best result with the stock tires. Soft are too sticky, and hard doesn’t pick up a good enough layer of dust. The stock Mediums seem to be great!
Edited by – M_Coupe on 27 September 2003 01:54:00
September 27, 2003 at 12:17 pm #39231
Does anyone have any videos of Bits actually drifting? I’ve seen 1/10 cars and mini zs drift before, but never a bit. A video of it just sliding around would be great too, I guess
September 27, 2003 at 6:17 pm #31495
Here is the Ph2t’s topic on lower the center gravity, and click on the video, u will see his Bit drifting across the floor:
http://www.ausmicro.com/topic.asp?TOPIC_ID=1239&FORUM_ID=9&CAT_ID=2&Topic_Title=Lowering+the+centre+of+gravity%2E%2E%2E%2E&Forum_Title=BCG+%2D+Technicalthe camera is a bit far from the car so u can’t really see some good drifting from the video.
September 27, 2003 at 6:59 pm #31468
Are there any other videos? I don’t seem to be able to see the video. oh, and whomever said less traction on the front was right. I tried it out with my mini z and now I can drift with the miniz!!! Just not my bit yet…
September 28, 2003 at 8:16 pm #31296
the tomy drift axle suxxxx..
synth oil for bearings is awesome on a track for sideways action. and leaves nice trails.
the trick is to place a bit on the outside of the corner so the front wheels dont get oiled up.
a few drops spread out with a playing card so you create a broad patch works best. and the best bit is that it dries up and doesn’t permanatly stuff your track. -
September 28, 2003 at 8:27 pm #31297Quote:Are there any other videos? I don’t seem to be able to see the video.
Get Divx from http://www.divx.com, nimrod…
September 29, 2003 at 1:24 am #31308
Death…. i managed to get my bit drifting with a supra body as low as it can go at the front and with soft tyres on the front and i fiddled with the rear tyres and found out medium works best with mine. with the motor only powering the rear wheels while the front wheels grip to the surface for dear life the back end whips out and hold its position for as long as possible. I’m going to perform the Bit Char-Q mod next week. you take the pcb out of a digi q and slap it in a bit(requires excellent soldering skills) and you have proportional throttle with the best digi q remote. lcd screen etc… ill post my vids as soon as i can get them on here.
September 29, 2003 at 10:14 am #32230
cool!! I finally bought a clone (audley car) and it’s got a motor with a green cap. is the motor any good for drifting?
