Iwaver 02 PCB
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › Iwaver 02 PCB
- This topic has 4 replies, 4 voices, and was last updated 20 years, 10 months ago by
dgs73.
January 27, 2005 at 7:52 pm #12531
Hello, I am on a quest to build suped up xmod… I was wondering if anyone has an Iwaver02 PCB that I can use.. Would it be worth my while to also use the Iwaver02 servo or change it out to a HS-55?
I am planing to do the Iwaver02 conversion with a Nelly Deluxe (I will wait for the new Nelly Deluxe like the website says.Here is my proposed setup:
CF chassis,
Rx-7 Body,
CF drive shaft,
All wheel drive,
CXP alloy one piece top-plate,
Iwaver PCB conversion,
HS-55 Servo,
Nelly Deluxe when it comes out,
Lith-Ion Batteries, (2 x 3.6V)
Full alloy suspension front and rear,
Alloy Wheels,
Metal Bearings,
Atomic Mods Nuke 130 motor,
Screw-in antennaDoes anyone see any problems with the above setup (Other than it being an expensive venture)??
January 27, 2005 at 8:34 pm #58289
i dont think anyones just going to give you an iwaver02 pcb. thats a problem:smiley2:
January 28, 2005 at 2:03 am #58294
i’ve used the xmod servo with an i waver pcb and it’s fine, i don’t see a need to use a hitec.:8ball:
January 28, 2005 at 3:06 pm #58301
I didn’t know I need to be that specific.. I wasn’t asking for someone to just give me a PCB…. I need to buy one from someone who has one… Does anyone have an Iwaver02 PCB that I can buy?
Betty k. Isn’t the Xmod servo worse than an HS-55.. I thought that the Xmods weren’t stepped as much as the mini-z and such,, hence the better steering in the kyosho cars..
January 28, 2005 at 4:55 pm #58302
i think z-beam’s point was you’ll have a hard time getting an iwaver02 pcb by it’s self, because no-ones likely to want to sell one and be left with an empty iwaver chassis (and who would?)… why not just get a chassis complete, minus tx and shell? Still cheap…
Edited by – dgs73 on 28 January 2005 11:58:28
