Iwaver Steering Feedback?
Home › Forums › General Chat › Iwaver Steering Feedback?
- This topic has 9 replies, 4 voices, and was last updated 19 years, 5 months ago by
June 29, 2006 at 11:04 am #9696
G’day
i was wondering if someone could measure the resistance of there feedback pot on a iwaverboard while at full left and full right also a picture of which 2 legs are shorted,
Im building a backyard flyer with Iwaver eletrics and i need the info to compleate my rudder “servo”
Cheers
Rohan -
June 29, 2006 at 11:49 am #28470
full left: 3.5 ohm
full right: 5.18k ohmi might have my left and right mixed up but i think that’s it.
attached pic is of iw servo pots. green wire on the right terminal and the yellow wire is connected to the middle and left terminal. :8ball:
June 29, 2006 at 1:01 pm #28411
ld you tkae it a step further and a pic of where the motor and pot wires are soldered onto the board (my diagram dissapeared)
June 29, 2006 at 1:41 pm #28413
Hey Merc,
I posted a diagram in this thread a while back…
http://www.ausmicro.com/forum/showthread.php?t=14089
Its the third post down !!!! it will give you all you need for the wiring !!!
Have fun..
June 29, 2006 at 2:08 pm #28410
That pic didn’t cover all of the iWaver boards I’ve seen – with the same orientation of the PCB as that diagram, the servo motor connects exactly the same, but the servo’s pot connects on the bottom edge, with the blue wire at the corner and the yellow wire just inside from it, but on the bottom edge.
The blue wire is connected to 2 pins on the pot, yellow to the other one.G.
June 29, 2006 at 2:11 pm #28391
more pics courtesy of namuna:topstuff: :8ball:
June 29, 2006 at 2:27 pm #28392
The colour of the wires going to the POT doesn’t matter !!! as long as it’s wired the same as in the diagram !!
June 30, 2006 at 11:58 am #28340
Thanks Trent, and RCS i fryed my board today sadly, looks like that project wonr be happening,
June 30, 2006 at 11:00 pm #28324
oops!
was worth a try :8ball:
June 30, 2006 at 11:48 pm #28323
im not sure how it fryed it just stoped responding to any TX signal
