my front suspension proto type
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › my front suspension proto type
- This topic has 13 replies, 7 voices, and was last updated 21 years, 10 months ago by
January 8, 2004 at 10:44 pm #11415
hey fellas, after a couple of days of thinking and drawing out ideas i finally found a way it would work. This mod is still in its early ages and doesnt fully work properly at the moment but i will fix that later on, im gonna try some londer nails. but there is still the ground clearance problem but that should be fixed with bigger wheels.
January 9, 2004 at 1:00 am #38055
whoa! dude! holy shit on a shingle….
how you gonna get it to steer?
mad! just mad!
January 9, 2004 at 1:03 am #38056
niiiice one brudda!:smiley2: re the clearance issue, you could make the bottom plate an upside down v shape instead of straight. it’s gonna be kick@55 with big wheels, keep us posted:8ball:
January 9, 2004 at 3:38 am #38050
thanks fellas,
ph2t- the steering system is just the same as the one that is already in the bit, the nails are attached to the first plate and when they go side to side it moves the plate side to side with the wheels and on the bottom plate i drilled some little holes for the wheels to move freely,(hope that makes sence) but the only problem i have with the steering is that the nails are steal and get attracted to the steering magnet.i should have it fully done by sunday and should have the wheels on tomarrow, for now i made this one for fun it doesnt work but it looks kool.
January 9, 2004 at 4:24 am #38047
heh heh:D funny car! have you thought of using wd 40 straws instead of nails? just a thought, nice mod:smiley2::8ball:
January 9, 2004 at 4:29 am #38046
nah never thought of that, i got a can of it somewere around here, and the end will have to have a flat top of some sort or something like that so it wont come thru the hole.
January 9, 2004 at 8:22 am #38039
A cigarette lighter’ll melt it enough to flatten a bit out…
I think the tacks you use for hang pictures are brass, so… lets get down to brass tacks! (bwahahahaha, I kill me) Only problem would be finding the right size.
Edited by – Pork_Hunt on 09 January 2004 03:27:58
January 9, 2004 at 12:49 pm #38028
how about wooden toothpics?
January 9, 2004 at 6:51 pm #38023
aluminium, is another option. pipeing is avalable wherever hobby train supplies are.
you can fan it out with a small screwdriver.
January 9, 2004 at 8:46 pm #38018
If the front is that high…how will the rear be like? I think u can make a super monstertrauk here. Great work.
And i think u can make it 4WD some how.:question: -
January 9, 2004 at 10:12 pm #38014
yeah i was thinking about making a mini drive shaft under the chassis but i dont no how i could hook it up with the engine.
January 10, 2004 at 1:59 am #38009
for the drive train to the rear you could use a belt drive, a rubber band from the motor the the rear axle would work. no torque though 🙁
January 17, 2004 at 1:31 am #37890
betty!!! you MUST get the lego chains out!!!!!!
the technics sets contain the perfect solution, gears and chains that you can add and remove the links out of. not to mention the flexable drive shaft systems available for a possible 4wheel drive bit.
January 17, 2004 at 4:16 am #37885
um, just checking, you know this is brendan’s gig don’t you?! but i do have some lego chain, might be a bit big for this application.:sad: we might have to wait for some genius in asia to design one and mass produce them:8ball:
