n00b questions
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › n00b questions
- This topic has 13 replies, 7 voices, and was last updated 22 years, 7 months ago by
mutionu.
July 23, 2003 at 3:17 am #11173
1: Does the charger have auto cutoff? (may i leave it to the charger if the light has gone off)
2: Where can i buy parts online? (motors,tires….)
3: Where can i get the small springs for the suspension mod?
4: What are the main advantages between Mini-z and Char-g?
5: Whats MDF board? (sry for my poor english)
6: Are there any window masks available ? (for painting)
7: How can i add pics to the members gallery? (im already registered)Edited by – mutionu on 22 July 2003 23:20:48
July 23, 2003 at 3:27 am #22929
1. ???
2. http://www.bitchargoz.tk
3. probably same as above
4. ???
5. MDF is Medium Density Fibre, just a piece of wood.
6. I believe http://www.tinyrc.com sell them, but they aren’t going to be really cheap, I just put tape on a window and cut around it with a stanley knife.
7. Have you applied for a gallery already? When you click on your user, there is a thing on the left which says upload new images, type in username and password, then choose your images, I think the total must be smaller than 1 meg.
Hope that helps. -
July 23, 2003 at 3:31 am #22931
1: Does the charger keep charging after 45secs?
2: I think they send only do Australia.
4: No need to answer that I thought they are the same scale but they are not.7: Ive applied to the gallery but i cant see my user on the list.
Edited by – mutionu on 22 July 2003 23:37:56
July 23, 2003 at 3:54 am #22914
1. no it stops charging after 45 seconds you have to take the car off and place it back on the charger for it to charge again.
2. other sites to buy parts are in the links in this website here
http://www.ausmicro.com/links_showsub.asp?cat_id=19&cat=Online+Stores -
July 23, 2003 at 4:12 am #22885
ahh sorry, I didn’t read in your title that you aren’t from Australia.
July 23, 2003 at 4:13 am #22886
You have to wait for Aaron to approve your gallery, as soon as he approves it, it will appear on the list with the others. Then you do as I said above. -
July 23, 2003 at 6:08 am #22888
ok thx alot!
July 23, 2003 at 5:48 pm #22411
bit_charg_oz will send overseas, but im not sure where etonia is .. ?
July 23, 2003 at 6:21 pm #22413
1. You can safely leave the car on the charger. It stops charging after 45 seconds. You only receive 45 seconds of charge.
2. Online you can buy parts from ToyEast, or HLJ. They ship world wide I think.
3. I think the springs used for slot car racing can be used for BCGs. They need to be non-magnetic, or it interferes with the steering.
4. Yup. MiniZ and Bits (BCGs) are different scale.
5. MDF is like craftwood. It’s cheaper than plywood, and probably not as strong. It’s like chipwood, but with a higher quality smoother surface.
6. You’re better off buying some masking tape, and cutting it to suit with an exacto knife or scalpel. (before putting it on the car if you’re not confident with the knife.
7. Good luck with the members galley. I’m sure you’ll work it out.
July 23, 2003 at 9:15 pm #22416
Yeah it can take me a few days to a week at times to create a members gallery. Becuase i do them manually it takes a little longer.
I’m looking at how I can automate the system more but at this stage we all have the extra bit of work 😉
The Members Gallery system has just been expanded as well so now is an even better time to create one!
July 24, 2003 at 3:06 am #22003
yeah, where is estonia?
July 24, 2003 at 4:06 am #22005
Look EAST Its under Finland.
And Btw Ive been in Australia 🙂 -
July 24, 2003 at 12:28 pm #22012
ahhh, thanks. I see it
July 24, 2003 at 9:03 pm #22056
1. All i know that a timer is in the circuit. it might control the charging i di=ont no?
2.http://www.towerhobbies.com
3. The mod is not worth it
4. Jsut the size . GO BIT CHAR G:”SSS
5.Basic manufactured wood. Made of dust particles. Cheap$$
6. Just use masking tape
7. So times it doesnt work
