new to this
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › new to this
- This topic has 14 replies, 1 voice, and was last updated 23 years, 4 months ago by
November 7, 2002 at 6:09 am #9491
Hi everyone I just bought a white skyline microsizer. I would like to know what I should do to mod it? Whats a good motor for going the fastest?
November 7, 2002 at 6:13 am #16896
Get used to driving around a track first. I think the stuff it comes with is a good alrounder. Soft Tyres, soft Stabs and springs all help it go better. Gearsets allow you to go for torque or speed. Faster motors arent all that good for track racing. Supra Race body is sexy get one.
November 7, 2002 at 6:19 am #16897
i got the kit. you have a 1.0 the slowest eng. with super soft tires and a hard stab. bar. your first mod should be takeing the criple cap. off the pcbord on the car tell me if you wanna do it i’ll tel you how. then get a 2.6 orange endbell. then take off your stab. bar to keep from rolling it.but how ta get the most bang for your buck go to radio shack and for $6 you get a 2.1 and a 2.4 stab bars gearing what is a kiler deal being the 2.6 is about $8
November 7, 2002 at 6:28 am #16901
Oh fine remove the suspension, goes like s#!+ compared to my car with soft stab and springs. It’s there for a reason, to keep the front end from losing traction.
November 7, 2002 at 6:31 am #16903
Ok This all sounds nice and cool and stuff. First
Where can I get a supra body?
Second- Im used to driving it- but is a 2.6 make a big difference in speed?
THird- whats a criple cap? whats the pc board? whats a stabilizer bar? Is it that white plastic peice across the 2 front tires?
fourth- heres what i plan on doing to it. Get a wheel and gear tuning set, Tire set, 2.6 motor all from Hobbico- is this a good idea?
THANK YOU FOR THE FAST RESPONSES AND THE ONES TO CONTINUE
November 7, 2002 at 6:42 am #16904
Yes, everybody has different opinions, so buy what you want and decide for yourself. The stab is the plastic thing over the front wheels, soft ones make the suspension softer, soft tyres have more grip…faster motors…make u go faster:smiley2:different gears make u faster or have better acceleration.
November 7, 2002 at 6:46 am #16906
Well how much faster is the 2.6 motor than the 1.0?
November 7, 2002 at 6:53 am #16907
alot the 1.0 is a turd as for the supra there none in the use. a soft stab and a stiff stab drive the same way try a 3.0 or a 3.8 i use dual batt.s hooking up a 3rd ta see if i can blow my old 2.6.
whare are you from? im from michigan
November 7, 2002 at 6:56 am #16908
Is the 2.6 a lot slower thant the 3.0 or 3.8?
Well I think for my first car I will stick a 2.6 in it anyway.
November 7, 2002 at 7:06 am #16911
the 3.0 is fast and the 3.8 is to fast and i got a 5.3 that holey sh*t fast. what state do you live in?
November 7, 2002 at 7:12 am #16912
New York
November 7, 2002 at 7:25 am #16913
The 1.0 runs 10000 rpm, the 2.2, 22000 and so on so you can get an idea of how each would compare to your 1.0
November 7, 2002 at 7:54 am #16922
When everything has been said and done, ie. you’ve got your Bit looking like you want it to look with the right body and colour/s, and you’ve got it driving like you want it, ie. the right gear ratio with the right engine and right suspension, you might want to try adding headlights to it. I saw someone in the forums construct undercarriage neons for their car!! The sky’s the limit for modding Bits. Just check out QFM racing for more mdding ideas!
http://www.questformadness.com– I think.
Anyway, have fun racing, and Good Luck with the modding!
November 8, 2002 at 7:20 am #17078
yeh QFM is a good site. Lots of info. Im getting the zip zap kit (fast and furious) from radioshack that has 2 motors 2. something and a 1.0. Ill tell you guys how they are over the weekend
November 10, 2002 at 6:56 am #17211
I got a zip zap tire and performance kit. I put the pinkish motor in with a little jamming since it is a little longer than a microsizer motor. I put red gears on it.
I also have a blue motor which I think is a 1.0?? Im not sure. Anyobdy know what the pink and the blue motor are?
Anyway the red gearing and the pinkish motor run much quicker than the old 1.0 and stock gearing. The tires are also A1! They grip much better.
