nitro Mini Z; real or no?
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › nitro Mini Z; real or no?
- This topic has 32 replies, 8 voices, and was last updated 21 years, 8 months ago by
jamiekulhanek.
April 2, 2004 at 4:48 pm #12073
ok guys, check this out: http://www.rc-crazy.com/
i m guessing it s fake, but… -
April 2, 2004 at 6:24 pm #50359
Looks like a product in development rather than something you can buy. Given that a .075 is equivalent to a 20t 540 (on 6 cells), it certainly would cause a MZ to fly.
April 2, 2004 at 6:24 pm #50560
April 2, 2004 at 7:26 pm #50360
Nitro + Mini-T… ’nuff said. 🙂
April 2, 2004 at 7:26 pm #50561
April 2, 2004 at 8:18 pm #50362
damn that looks cool.
i wonder if it is real? probably releasing photos to gauage public reactions?
that site is cool aswell nice big arse track for a mini z there!
April 2, 2004 at 8:18 pm #50563
April 2, 2004 at 8:18 pm #50363
I think maybe another April fool’s day prank, the timing’s right…
April 2, 2004 at 8:18 pm #50564
April 2, 2004 at 8:20 pm #50364
‘Fraid not. That’s been around since about Feb. 😯
Someone at Tamiya also installed a nitro FS12
into a Tamiya miniyon (mini 4X4) chassis.I guess its not R/C but…! :p
April 2, 2004 at 8:20 pm #50565
April 2, 2004 at 8:23 pm #50365
no, I mean the Mini z nitro:smiley2: The photos look a little touched up, but who can tell?
Nitro in a mini 4wd? Strewth!!:shock: -
April 2, 2004 at 8:23 pm #50566
April 6, 2004 at 4:25 pm #50415
Ive been thinking about it….i have stacks of cox engines at home.
.010, .020, .049, .061. I also have instructions on how to make an .049 engine have reliable throttle control, using a throttled carb and exhaust sleeve. Also have a diesel .049 but its full throttle only.
.049 powered MZ hmmmm.
April 6, 2004 at 4:25 pm #50616
April 6, 2004 at 4:36 pm #50416
this takes your modding in a new direction, eh Jamie?!?:smiley2:
April 6, 2004 at 4:36 pm #50617
April 6, 2004 at 5:19 pm #50418
I’ve been thinking the same thing, throttable .049, but in my Xmods since it’s so slow, and then the gears won’t seem so loud :p
April 6, 2004 at 5:19 pm #50619
April 6, 2004 at 5:24 pm #50419
i reckon you would meatloaf the drivetrain though….
April 6, 2004 at 5:24 pm #50620
April 7, 2004 at 5:46 am #50432
I wonder if MRS4 gears diffs might be made to work, guess it would be a custom 1/28 NMRS4 then…
Xmods gears are fairly coarse pitch and seem OK. Maybe a .020.
April 7, 2004 at 5:46 am #50633
April 10, 2004 at 11:47 am #50697
April 10, 2004 at 3:00 pm #50698
yeah and that page says april fools at the bottom so go figure….:question:
April 11, 2004 at 4:51 am #50711
That would be sweet!
BTW how do you control throttle on COX .049 engines?
April 11, 2004 at 8:48 am #50714Quote:i reckon you would meatloaf the drivetrain though….
Bolt it to the roof and use a 4″ prop! :D:D
June 27, 2004 at 6:15 am #52881
yeah
June 27, 2004 at 6:56 am #52886
I’ going to have to do this one day………….
The donor vehicle would have to be an Xmod…..well…..the drive train and some alloy drive cups with a custom chassis and HS55’s with micro RX…..
I have a few different pee wee, tee dee, killer bees etc.
The range of engines here goes from .010 (too small) to about 1.40 (bigger than the whole car)
I’d settle on an .049, seems the best for the job.
To get the .049 working with a throttle you need to put a throttled carb (and filter!!) with an exhaust sleeve linked to the carb.
Hey!! Anybody thinking micro tuned pipe??
The gearing etc can be worked out , and these motors don’t have huge torque, so gears should be ok.
The biggest problem is finding a clutch that will work. I have a very small 10mm nylon clutch, though it isn’t suitable, im sure one can be replicated (15mm??). A throttled .049 idles at around 5000-6000 RPM, so some heavy clutch spring will be needed.
A cooling fan is also vital to prevent servere overheating.
Lastly, some sort of exhaust system needs to be developed, having oil allover the place isn’t much fun. It also can affect performance, my 1/10 nitro buggy came stock with an exhaust that blew onto the left rear tyre, which made accelerating hard very hairy.
I have some experience with Nitro RC’s, and while this would be fairly challenging, the end result would be damn worth it.
June 28, 2004 at 1:04 am #52893
Looking more into this, the power plant of choice would be an AP .061 Wasp Throttled engine.
Though being bigger than an .049, it has many good features, dual ball bearings, ABC construction (aluminium piston, brass sleeve with chrome plating) which make it much more attractive than a cox engine, and at just 39.99 US, it’s a bargain.
June 28, 2004 at 5:04 am #52896
There is a Norvel engine that is .061 or something like that with those features but you can get a clutch for it.
BTW Good luck and I hope to see what this turns out like!
June 28, 2004 at 5:31 pm #52911
Do these 49s run on nitro or Cox model fuel? (aka ether or acetone)
June 28, 2004 at 5:36 pm #52912
Oh dude i’m not attempting this yet, ive got way too may projects on hand, can you give me the link to the clutch….future plans/dreams won’t hurt.
Wills, the cox .049’s run on the “cox” fuel, the other .061’s are basically smaller versions of larger engines. They run on normal glow fuel.
I’m thinking it would be best to run it on “buggy” fuel, due to the different application. But i may be wrong.
