overheated car
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › overheated car
- This topic has 16 replies, 6 voices, and was last updated 21 years, 4 months ago by
HACHI-RYOKU.
July 22, 2004 at 3:44 pm #10564
after charging my dual cell bit, my shell was warming up. afterward, i removed the shell to find that my pcb overheated and had a smell of melted plastic. i didnt gas, reverse, or steer while charging on its 4 AAA charger. So why did it overheat??? thanks…
July 22, 2004 at 3:55 pm #30930
did you have it connected the wrong way around??
July 22, 2004 at 4:01 pm #30931
which ones the wrong way? the charger or the cells?
July 22, 2004 at 5:07 pm #30933
when you connected the battery pack to the charging plate.
either that or you left it charging too long…
July 22, 2004 at 5:13 pm #30934
it only charged for 45 seconds or less and the charging port was connected correctly
July 22, 2004 at 5:23 pm #30943
so once you stopped charging and separated the car from the charger it worked fine?
July 22, 2004 at 9:16 pm #30955
with charging connect + to + and – to -. sounds like a short somewhere, check for loose wires or metal touching where it shouldn’t:8ball:
July 22, 2004 at 10:16 pm #30949
yeh or if u was reving it or any thign board will warm up because 4.8V
July 23, 2004 at 11:57 am #30917
its working fine now but it still heats up a little while charging…
July 23, 2004 at 2:45 pm #30920
How did you wire the cells?
July 23, 2004 at 2:59 pm #30922
its soldered
July 23, 2004 at 5:59 pm #30942
its official, the pcb board is totaled :angry:, and i didnt even rev it up while charging
Edited by – Raging RCer on 23 July 2004 13:59:45
July 23, 2004 at 6:49 pm #30938
hmm.. the correctly polariesed?
July 23, 2004 at 10:31 pm #30895
polarized… is english your first language merc?
July 23, 2004 at 10:37 pm #30896
nah i learned australia first.. im as white/english as it gets
July 24, 2004 at 1:11 am #39578
Sounds like something was shorted out or you had a bad battery.
All Auzzies speak a strange language. I visited a couple times and I always said “huh?”.
July 24, 2004 at 1:13 am #30840
my point exactly i live in balwyn (its abit snobby) and with my shitty english they think im for coboug or sumthing (no offence to any one form coboug)
