pull back wheel mod
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › pull back wheel mod
- This topic has 16 replies, 8 voices, and was last updated 22 years, 5 months ago by
brendan.
September 13, 2003 at 1:22 am #11380
recently done the pull back wheel mod but when i put it on the ground and press go it just goes around in circles i have checked the steering and nothen wrong with that and sugestions???
September 13, 2003 at 2:27 am #36332
Hve you made sure teat both front wheels are moving freely(not tight) and that there is no slip between the rear rim and axel.
September 13, 2003 at 3:09 am #36334
yer the wheels spin good on the front and they wheel and the axel dont slip
September 13, 2003 at 3:25 am #36336
have you tried stepping on it, or riding over it on your bike?
September 13, 2003 at 3:31 am #36337
haha i always stand on my cars not on purpose but i dont think i will ride over it
September 13, 2003 at 4:57 am #36348
The rear tires have different dirt grades I guess. One tire has better grip than the other, and therefor it goes in circles. Try racing it on another surface.
/Trackmaster
September 13, 2003 at 1:43 pm #39407
it does it on any surface
September 13, 2003 at 3:51 pm #37523
are both wheels on the rear axle solidly attached?
sounds like one slips.. -
September 13, 2003 at 5:08 pm #37525
yer they are on there tight they dont slip at all
September 13, 2003 at 5:17 pm #37526
its gotta be one of to things.
One of the front wheels is not spinning freely/catching the chasie or one of the back whelels is slippin.
What did you fil the back rims with before you put the axle on?
September 13, 2003 at 5:37 pm #36935
i havnt done the back wheels yet i couldnt be botherd, im just using the normal rear axels
September 15, 2003 at 5:30 pm #34007
you might have put one of the nuckle pins in too tight, or one of them might be filled with fluff…
September 15, 2003 at 7:44 pm #34013
r they on straght take them off n roll them down a peice of cardboard n if the wobble then there not on stragit u shouldnt be able to tell there rolling
September 15, 2003 at 10:12 pm #34018
Might have buckled/bent the axle when you put the wheels back on???? Just a guess.
September 19, 2003 at 7:19 pm #33360
I saw a poest about if the rear wheels are loose, the car will turn to a side whenever you go forward… is that what’s going on?
September 20, 2003 at 2:57 am #33538
I dont think he has modded the rear axle yet, so i think we’re ruling out anything to do with the rear.
September 20, 2003 at 3:28 am #33543
i couldnt be botherd tryen to get it wokring so dont worry any more
