I found a car I started and messed up a few times and decided to turn it from a racer to a street rod.
It started life as a clone S2000.
Then it got slot lowered.
Chopped the top and added aluminum tail pipes and a wing as well as the normal air dam and side skirts.
Added a few pipes out the hood for the engine (I thought it would look cool even though I can’t remember what they are called.)
Because of the pipes in the hood I had to put in a spring suspension because I had to remove the bar and hack into the cover of the steering.
Here’s a shot with the flash turned off.
Yes I even painted the PCB cover the same color.
And here is my little helper, when she was a few months younger. She hops in my lap when soldering and tests the hold of the glue joints by batting the bodies off the table. There is a reason I call her Miss Patches Underfoot.
Now can the little Hobbit finish the third Bit Pimps entry in time.
