Removing front wheels?
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Removing front wheels?
- This topic has 12 replies, 3 voices, and was last updated 23 years, 2 months ago by
October 24, 2002 at 5:05 pm #9398
Just wondering how this is done as the wheels on my 2000GT-R chassis are grey and when I want to do a gear swap I’m left with Grey on the front and chrome on the back. Swapping chassis isn’t an option as this is the booster car.
Is there info on how to do this anywhere?
Cheers
October 24, 2002 at 6:43 pm #15993
Found detailed instructions here FYI anyone else who isn’t too sure.
Putting them back together isn’t so easy – requires patience 🙂
http://www.blackadderhall.com/bitchar-g/garage/steering.shtml
October 25, 2002 at 10:29 am #16036
Hey i have a microsizer and on the rod that holds the wheel to the steering knuckle has like ridges on it so it doesnt pop out if want to change rims. Does the bit-charg have these ridges? If not could someone give me a few pointers on how to remove them because hitting it with a nail and hammer dont work.
October 26, 2002 at 7:49 am #16078
go check out qfm!!!!
not any hammer!!! i got a little hammer with a set of precision screwdrivers and i used it and a pair of sharp nosed tweezers to slowly knock them out.
you need small tools for small cars!!!!
ask if you need tell if you know.
October 28, 2002 at 4:20 am #16211
Rather than use a precision screwdriver, I filed the point off a small nail. This way my screwdriver still has some “precision” :smiley1:
I use a small tack hammer for the banging part.
October 28, 2002 at 7:12 am #16218
genspec whats that supposed to mean????:smiley13:
October 28, 2002 at 8:30 am #16222
I just meant that I didn’t destroy the end of my screwdriver so I could still use it for those little fiddly jobs.:smiley1:
October 28, 2002 at 4:27 pm #16273
Instead of swaping therims why not just swap the whole wheel and the plastic turning thingies with anther set by dissmating the front end there is a good turorial on this site and then you dont have to run the risk of Smashin the rims
October 28, 2002 at 9:30 pm #16275
I’ve removed the rims from a genuine Bit Char-g using a small screwdriver and hammer. Yes, the original Bit Char-g has barbs on the front axles which makes it much more difficult but you just have to hit harder. The trick to not bending your rim is DON’T HOLD THE RIM WITH PLIERS!!! Drill a hole in a piece of wood big enough for the axle pin to go through. Then put the wheel down on the wood and pound the axle out through the hole you just drilled. This way you have even pressure all the way around the wheel as you’re pounding the axle out. I’ve done this a number of times with great success. The only problem with the barb type axle is you can only pound them out 5 or 6 times before they start getting lose.
-Peter
October 29, 2002 at 7:15 am #16290Quote:Originally posted by Lazboy on 28October2002
Yay – I was waiting from someone with a bit of common sense..!! :smiley10:
Definitely, if you’re only swapping wheels between BCGs, then just swap the whole steering knuckle assembly – it’ll take you less than 1 min.
Pulling the axles out will invariably damage something, you’ll never be able to secure it like new again, something will be out of kilter somewhere. Its the only choice if you wanna put non-BCG hoops on, but if you’re just only swapping BCG wheels then that’s pretty silly.
October 29, 2002 at 8:43 am #16303
Yes points for ME
October 29, 2002 at 10:13 am #16314
:smiley4: BLUE R34 OWNERS UNITE oh yeah!!
November 5, 2002 at 8:30 am #16699
i always seem to damage the steering knukles.the tac digs into the knukle or the knuckle beend or the rod bends no matter what i do. its beccause of the barbs on the rod???
NEED HELP PLZ PLZ PLZ
