Some battery charging consideration
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Some battery charging consideration
- This topic has 4 replies, 4 voices, and was last updated 23 years, 1 month ago by
Efarel.
February 5, 2003 at 2:36 am #10863
Hi,
last night I built a simple stand off charger with 4 AA batteries and the clip from a spare controller.
I’m not a big fun of the battery2battery charging but I had no time to build a proper charger (it will be my next project !).
By the way, I charged a car for 5 minutes and the battery inside (standard 60mah) was not even warm.
The car sprinted on my circuit for a very looong time, I had 28 minutes of driving time !!
28 minutes of driving time, ie no slow car ranting on the straight but good old driving time !! After 25 minutes of speeding I was tired and a sort of nausea was coming up !! Too much time !
Tonight I’ll charge it for 3 minutes and I expect 15 minutes of driving time.
A note… with the antenna mod http://www.geocities.com/bitcharitaly/micro_topi_modificati.jpg and the more serious charging I can control better, a lot better, my little car. It is more responsive in steering and the reaction time was minimized.
I’m now going to build a simple no timer NiCd charger with a LM317 as regulator. Stay tuned !
Efarel -
February 5, 2003 at 5:10 am #41708
it will work man but dont expect your bats to last long. pick up some NiMh cells ( 1/3 aaa) for your bit, theyre rated at 120mah
February 5, 2003 at 7:06 am #41709
hmmm
imho i tink that a better charging/decharging routine is better for the battery.Ok, we are ultra rapid charging those little battery at 45 seconds so we’ll charge/decharge it more time then with a single longer charge.
Less frequent but longer charging cicles will preserve the battery more than a lot of 45 sec charging.
Btw how many minutes do you drive with a standard battery and a standard 45sec charge ?Efarel
February 5, 2003 at 3:00 pm #41695
How cold is your surrounding ambient temperature?
imho The battery is probably too small to retain much heat, you’ll not be able to notice much heating effect. Tiny batteries also have more surface area vs volume compared to a larger cell, so has better heat transfer.
If its overcharged it’ll just vent its electrolyte silently and doubt you’ll see any trace of that.
February 6, 2003 at 5:35 pm #41670
hey efarel, that charger idea using an LM317 is great! I take it you are going to use it in constant current mode. Couple this with a 555 timer circuit and you will have a pretty could charger. You could then mod it for selectable voltages (for all the dual, triple cell mods out there…..).
keep up the good work!
