terrorist car!!!!
Viewing 6 reply threads
    • #11405
      merc-blue
      dos ne 1 think its worth it? blowing up a wild cahr g i might wrap it in foil to try to prevent damage basicaly im sing a couple of fire crackers and a fuse from a model focket hooked up to the pcb when i press the button for the spiclial finchtion it blows?? also i think i might try it with a solid fuel rocket engine n see how farst it goes??
    • #39358
      jamiekulhanek
      Hahaha im so gunna do that, drive a bcg into a shop, and blow it up, i guess if you filled a packet up with gunpowder and put it under the shell, with a fuse operated by reverse.
    • #35426
      oxhadokenxo
      Be sure to get the right gunpowder…some of it is slow burning and will just make a poof of light and smoke but no explosion…Gunpowder that ignites fire crackers or something a little bigger is always good..but try at your own risk..it is dangerous.
    • #35510
      jamiekulhanek
      The bit will be far away tho.
    • #35807
      jamiekulhanek
    • #35512
      merc-blue
      im intend on blowing up the car!!! park it out the frount n blow it up!!!
    • #35809
      merc-blue
