Tyres, tyres and more tyres!
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Tyres, tyres and more tyres!
- This topic has 20 replies, 12 voices, and was last updated 21 years, 7 months ago by
jamiekulhanek.
May 24, 2004 at 9:21 pm #12163
I was browsing through rcmart.com when i came across different types of tyres.
Normal
Normal Fiat
Semi Wide
Semi Fiat
WideWhat the different between them?
Anyone what type of tyres do a Mr-o1 NSX 2002 use?
Is wide but i m not sure if they are semi wide or wideCheers:D
May 24, 2004 at 9:22 pm #51698
I think there is typo there on rcmart, is says Fiat but when i click on the actual product it says flat~
May 24, 2004 at 11:22 pm #51700
Take it down to your local hobby shop and find out the size of your tyres and what ever other specs you are not sure of.
Pretend like you are going to buy heaps of stuff. Then just go home and find the best prices on e-bay!!!
May 24, 2004 at 11:38 pm #51703
tim, wide tyres are the ones for the rear of ur nsx and also for a few others, the clk, ferraris, porshe taisan, taisan viper, and some others. the front are mainly normal i guess…….
May 24, 2004 at 11:52 pm #51704
What are semi-wides than?
What makes them flat than?Cheers
May 25, 2004 at 2:39 am #51708
Semi wides are 9.5mm wide. Don’t know which cars they suit.
Flat tyre is better than normal tyre because more contact with the graound.
Normal is rounded, and when brand new they’re like cheese cutters, with only about 3mm of the 8.5mm tyre in contact with the ground.
May 25, 2004 at 2:21 pm #51715
Normal – is 8 mm wide and rounded tyre, which is for all Mini-Z front wheel, and some normal Mini-Z rear wheel. Such as ECHO, Viper, Subaru, RX7, Lancer, Porsch, Beetle, Focuse, AE86, S2000, BMW Z8, etc.
Normal Flat – is same as Normal but FLAT.
Semi Wide – is 9mm wide tyre, which is design for optional wheel, Kyosho wheel parts: MZH8/8S,MZH6/6AM,MZH3, etc.
Those wheels are design for the normal wheel base car as rear wheel to make it wider than normal.Semi Flat – is same as Semi Wide but FLAT
Wide – is 1cm wide tyre, which is for wide wheel base Mini-Z, such as Benz, Supra, NSX, Diablo VT, Skyline GT-R, F40, F50, F355, F360, Prosch GT3R, Corvette, LANCIA’78, ENZO, F575, 350Z, Melean F1GT, etc..
Quote:I was browsing through rcmart.com when i came across different types of tyres.Normal
Normal Fiat
Semi Wide
Semi Fiat
Is wide but i’m not sure if they are semi wide or wideCheers:D
May 25, 2004 at 3:00 pm #51717
wow! ken! you know your stuff, thanks for that! helps me out as well!
May 25, 2004 at 3:54 pm #51718Quote:wow! ken! you know your stuff, thanks for that! helps me out as well!
You are Welcome. If it has something in-correct, please update me!
Thank you.
May 25, 2004 at 4:16 pm #51719Quote:Wide – is 1cm wide tyre, which is for wide wheel base Mini-Z, such as Benz, Supra, NSX, Diablo VT, Skyline GT-R, F40, F50, F355, F360, Prosch GT3R, Corvette, LANCIA’78, ENZO, F575, 350Z, Melean F1GT, etc..
Just a little typo that’s all, it suppose to be 10cm wide. Thanks for all the info Ken. Helps heaps.
May 25, 2004 at 4:35 pm #51721
hehehe… you’re both wrong… 11.5mm or 10.5mm(not 1cm, most definately NOT 10cm wide… wtf!?!?!) is the rear size of AMG, Supra, NSX,(Tim!!!) etc. The rears have no offset, but the fronts off these models have standard width wheels, with 2.5mm (approx.) offset. Narrow bods use 8.5mm all round, with no offset. Others, like Jay-Z’s WRX or Kevsta’s Ferrari have custom offsets… My XaNaVi has 11.5mm rears, with an additional 1.5mm offset. H e a p s wide!!!
May 25, 2004 at 8:47 pm #51725
Well thanks any dgs and Ken
May 25, 2004 at 8:49 pm #51726
Sorry All, and Thank you guy,
I check the information from Kyosho Web-site. The correct tyre size is 25?8.5mm for front/normal 25×9.5mm for semi-wide and 25x11mm for wide tyre. Please keep update me if it is in-correct.
Thank you.:D
Edited by – ken_wyleung on 25 May 2004 16:54:42
June 22, 2004 at 2:08 am #52650
hehe wow.. this wealth of info just taught me all i need to know.. now i can buy sum tyres..
thanks guys
June 22, 2004 at 8:23 pm #52669
so a stock wrx comes with normal width rims and tyres?
July 31, 2004 at 10:50 am #54087
hey.. about tires and wheels..
On rc mart or anywhere when it says wide tire set.. or wide wheel set.. and it comes with 4.. does that mean 2 wides and 2 normal? or are they all wide?
July 31, 2004 at 10:50 am #54445
July 31, 2004 at 9:28 pm #54092
when it says “wide” on tyres, that means they’re all wide:8ball:
July 31, 2004 at 9:28 pm #54450
August 1, 2004 at 1:38 am #54101Quote:hehe wow.. this wealth of info just taught me all i need to know.. now i can buy sum tyres..
thanks guys
Um, you have worked out the sizes….BUT
there are about 8 different compounds available………
August 1, 2004 at 1:38 am #54459Quote:hehe wow.. this wealth of info just taught me all i need to know.. now i can buy sum tyres..
thanks guys
