xmod w/lithium/nelly/andpns01 motor
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › xmod w/lithium/nelly/andpns01 motor
- This topic has 7 replies, 4 voices, and was last updated 20 years, 7 months ago by
August 4, 2005 at 2:00 pm #9905
I have a 94 mustang xmod with all of the gpm hop ups, 7.4volt lithium pro kit and the nelly v1.1, I want to get some awesome speed and ordered a pn s01 motor, I got it for 5.00 what cam I expect for speeds?
August 4, 2005 at 11:45 pm #19164
enough to make you say ‘JEEEEEEEEEEEZZZZUS!!!!’ out loud
that’s a pretty torquey setup, use the 11t pinion setup if you have it.
August 5, 2005 at 3:00 pm #19152
Well guess what ? I put the pns01 in today and fired the reverse fett on my nelly. That was dissapointing. Im gonna replace the fet and go back to my stage two red {9} tooth pinion I like the get up and go on that one, my track is only about fifteen feet on the straight away so its quick enough. My miny z really tears up that course.
August 5, 2005 at 7:04 pm #19125
a STAGE 2 cannot compare to a S01. you DONNOT have a S01.. a S01 is like a trinity D5 flatwire 6turn of 1:24/28
August 5, 2005 at 7:30 pm #19124
Question time….
Why couldn’t he be running a PNs01 like he says he is,
If it has a Orange sticker on it then my guess is that its a pnS01….Can somebody tell me the diff between the S01 and a S04
I think i know the answer to the Q But i want to make sure. :smiley2:And what the hell is a trinity D5 flatwire 6turn of 1:24/28 suppose to mean :smiley2: Are you Talking wire Grade or What :huh:
I don’t understand you at times Merc :smiley2:
Edited by – peteWah on 05 August 2005 15:36:44
August 5, 2005 at 9:29 pm #19121
the s01 is a 37t arm, ferrite mags. s04 is a 35 turn arm, neo mags, bb can.
August 6, 2005 at 1:31 am #19122
opps i got s04 and s01 backwards..
August 6, 2005 at 1:56 pm #19118
I do have a pn s01 motor, I just got it from jaw drop racing a few days ago. I know that the stage two does not compare performance wise but on my particuler setup it really works well. My track is 2foot by 2 foot foam tiles, very grippy, and I’m now running lithiums on an xmod loaded with all of the gpm alloy parts, On board tight turns, and wide track sealed bearings, compared to stock batteries with a 9 tooth stage two this rocks. the main reason I bought the nelly turbo is to keep the motor heat down and for the smoothe controle, not neccessarily for the use of a more powerfull motor. the lithiums in my opinion give an xmod all the spead you need with a stage two. seriously anny faster and the cars are to hard to controle in serious races on small courses, especially if the lanes get narrow.by the way my track is not 2foot by two foot, the tiles are and I have about 40 of them. were using 2 inch pvc as edging with insulating foam around it to protect the cars
