zipzap hubcaps
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › zipzap hubcaps
- This topic has 13 replies, 6 voices, and was last updated 21 years, 8 months ago by
merc-blue.
June 14, 2004 at 11:59 pm #10610
hey dudes,
can you get the zip zap hubcaps and put them onto SBCG? i reall want some but do they fit? -
June 15, 2004 at 12:02 am #32506
if u have the origional wheels off a ZZ they click on and off if memory serves me corectly
June 15, 2004 at 12:38 am #32505
nah i dont, i was wonderin if u could glue them onto a SBCG wheel set or mod them so the fit or sumtin like dat coz i seen those german alloys and i dunno where to get em so i wanted to know if u could use the ZZ ones…
June 15, 2004 at 1:38 am #32504
the german alloys can be gotten form bitpimps every now and then. i got 2 sets
June 15, 2004 at 9:39 pm #32490
hmmmmmmmm r they cheap?
June 16, 2004 at 6:23 pm #32465
theres a new wheel upgrade kit for zipzaps i jus got. it comes with spacers to make tha wheels wider to fit tha new wider tires. their pretty wide. like 3 normal ZZ tires stuck together
June 16, 2004 at 7:35 pm #32463
kool, but my question was do the hubcaps fit on BCG/SBCG?
June 17, 2004 at 1:30 am #32434
nice idea, to just glue ’em on to bcg rims. wish i had a few to have a go with.
i think betty’ss got himself one, drop him a pm and maybe he could check for us.
June 17, 2004 at 1:46 am #32417
yeh i was thinkin just get a set of the wheel-rim upgrade kit for ZZ and pinck the hubcaps, glue em on and let em shine! il PM betty and check…ill notify u z-beam
cya rob -
June 18, 2004 at 8:28 pm #32406
thanx, i look forward to the results…
June 18, 2004 at 9:57 pm #32399
zz hub caps are designed to be used with zz wheels. and bcg’s are designed to drive on tabletops. see where i’m going with this? i’ve never tried it but with a little grinding and glueing i’ll bet it can be done. and when someone says “don’t bother it’s too hard” then prove em wrong!:8ball:
June 19, 2004 at 2:31 am #32355
wel i might just do that!
June 19, 2004 at 7:17 pm #32354
I’ve done it. It works well. I took the front rims off the ZZ knuckles and put them on the bcg knuckles. The back rims come off easily. The only problem was that the front wheels are a little bigger than the regular bcg wheels, so you’ll have to file/dremmel out some room on the front wheel wells on a bit. They are also a little heavier, so you might want to put an extra return spring on the steering. Maybe not though. Try it first, then decide if you want the extra return spring.
June 19, 2004 at 8:09 pm #32328
thanx betty! now all i need are some zz hubs…
