Re: Extending Charge Time Mod
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Extending Charge Time Mod › Re: Extending Charge Time Mod
March 1, 2003 at 1:37 am
#40210
In both cases Genspec, I would try doubling the larger capaciter.
The nano’s 100uF can go up to 220 uF 10V
The compact’s 47uF can go up to 100uF 10V.
If it doesnt work, just replace the originals.
Be careful with the polarity of the capacitors tho.
One leg will have (-) (-) (-) down the side of the capacitor. Make sure it stays on the same side when you replace the capacitor.
Good luck, let us know how you go.
:)uA
