Re: Firelap 2.0 Transmitter setting – problems
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Firelap 2.0 Transmitter setting – problems › Re: Firelap 2.0 Transmitter setting – problems
welcome aboard!
the first thing i’d check is the trims on the tx, make sure they’re centered.
fiddle with the throttle trim until the motor turns forward, then back it off until it stops and is quiet.
if the steering is still off center you may need to adjust the trimpot on the pcb (see attached pic) until the steering is mostly centered. then fine tune with the steering trim on the tx.
TX= transmitter
RX= reciever
REV= servo reverse (if the steering is backwards then turn rev “on” for ch1, same for throttle, ch2)
MDL= model (a group of settings)
EPA= end point adjustment (individually adjust l/r steering travel, f/r throttle)
ABS= anti-lock braking system (ignore this, it don’t work on the iwII tx:dissapprove: )
NAME= 3 character name for each model
CH= channel (ch1 = steering. ch2 = throttle. ch3 =?:huh: )
see how that works out for ya and keep us posted :8ball:
