Re: How to strip down an AWD to clean the steering setup
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › How to strip down an AWD to clean the steering setup › Re: How to strip down an AWD to clean the steering setup
Hay Renton,
No problems Buddy, I’m glad it made your first pull down allot easier !!
I’m not so glad that it didn’t fix the problem though!!!
A few questions for you !!
1, Can you explain exactly what is happening??
2, Did you clean the POT out with circuit board cleaner ???
3, Do you have or know anyone with another TX (transmitter) you could try with your car to narrow the problem down a little more ??
While your pulling it down “again” LOL, just double check everything as it only takes a microscopic rock to jam it all up, I normally check between each tooth on each cog to make sure !!
Let know… :topstuff:
RCS
