PCBs can be sandwich glued together with epoxy to double their thickness, usually plenty strong if you avoid the pre-drilled veroboard stuff.
CF is a bugger to cut & file. Your drills and files go blunt extremely quickly, even high speed steel and diamond files aren’t much tougher. Plus I also try to file/cut under water to avoid wearing big chunky repiratory masks.
