Re: MR-01 PN Alloy Motor Mount
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › MR-01 PN Alloy Motor Mount › Re: MR-01 PN Alloy Motor Mount
September 14, 2004 at 6:21 pm
#55476
Quote:
cheers DGS, i`ll look up some stuff i need to quote & give it go.. & yeah, is there ever a need to put spacers behind the metal motor mount clip (that goes on the stock plastic mount)i bought the other day? cant figure how i`d adjust it for spacing requirements when using 10 tooth+ pinion gears??
If your using the stock motor mount with metal clip than I think the largest pinion you can go is with the 9 tooth – although I think dgs and talldude have managed to slip in a 10 tooth in there !?. You will need the motor spacers between motor mount and motor, but non between the motor and metal motor clip. The clip is a tight fit.
For the full alloy motor mount, the largest I can fit in there is the 14 tooth pinion with near perfect meshing.
Sorry to hear about your peugeot. So you going to fix it, or get another car ?
