Re: my “Woah Nelly!” Turbo….
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › my “Woah Nelly!” Turbo…. › Re: my “Woah Nelly!” Turbo….
Ok, lets bring this bugger back on to topic.:evil:
I’ve now changed the layout of the PCB to move the motor mount to one edge. This helps with the alignment when nelly is installed. I’ve made just a few (physical) improvements on the original design in terms of layout and total size.
Here’s some updated shots of the latest version of nelly.
As you can see, setup is pretty simple. Solder the 2 power wires to the +/- battery terminals. Solder the 4 (rainbow) wires to the RX pcb, two soldered per mosfet package. Then you just need to terminate the motor cables into the orange wire block and you’re good to go!
cheers,
Edited by – ph2t on 28 June 2004 23:09:26
