Re: The car is dead!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › The car is dead! › Re: The car is dead!
Hi ya all
I?ve tried to charge the car on another controller, the car works when placed on the charger, but no reaction when I pull it off there.
The battery is inserted correctly, otherwise I guess the car wouldn?t work on the charger.
I have bent the contacts a little to obtain better contact with the battery without any result.
I can?t see any loose cables anywhere, so I?m left out here in the blue.
Another question (I haven?t tried this myself yet, just came to think of it): Would the car run when placed on the charger if the battery was not present? If it doesn?t run then there can?t be anything wrong with the contacts, I guess.
/Trackmaster
