Re: the range is a bit short . .
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › the range is a bit short . . › Re: the range is a bit short . .
May 2, 2002 at 6:10 pm
#13278
rye256
A friend of mine had similar problems with his car when he first got it, we ended up pulling it a apart and found a blob of solder flying around within…
I’m not saying this could be your problem as well, but it might be worth your while to carefully pull the car apart and have a look see if all is ok…
Particularly look closely @ the solder of the antenna wire, as this is where I suspect my friends stray blob of solder may have come from…
Just take care when opening it up…
