10,11,12t pinions? (MR-02)
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › 10,11,12t pinions? (MR-02)
- This topic has 23 replies, 7 voices, and was last updated 21 years, 7 months ago by
dgs73.
June 28, 2004 at 5:50 am #12218
I m after some bigger pinions for my MR-02.
Where can I get some?
I ve seen some megatech(?) ones somewhere, but wasn t sure if they re the right size.Also, will I need to mess around with custom spacers/motor clips to get the big pinions to work?
June 30, 2004 at 1:43 pm #53019
once you go above 9 tooth pinions you are needing to modify the mount abit to mesh the gears properly. I use HPI on my Zs, up to 13 tooth, plus they’re stainless steel so wont be wearing out like the plastic ones
July 2, 2004 at 12:08 pm #53082
What about OL pinions?
July 2, 2004 at 9:05 pm #53100
i have used monster pinons on my z works great but be prepared to lose a motor or some stock fets!
i did it for the hell of it.
not sure if o/l and monster pinons are the same but if they are it should work!
July 5, 2004 at 1:15 pm #53181
as long as you get the meshing right all should be cool
July 5, 2004 at 2:24 pm #53185
i dunno if mr01 and 02 are the same as far as gears, but on my 01 i’ve used monster pinions, mrs4 and “proper ones. the biggest pinion i could go with the stock motor housing is 11t. monster pinions are a bit shorter than proper ones so they tend to move around as they aren’t holding on to as much motor shaft. i’m currently using an alloy 10t mrs4 pinion and i’m 100% happy with it:8ball:
July 13, 2004 at 4:35 am #53448
I seem to wearing out 9t pinions a lot… so alloy would be good. Do the alloy pinions damage the spur gear at all?
My MR-02 has been sent inside for misbehaving in the carpark. Could I safely put a bigger pinion in my iwaver? It seems to have plenty of grunt with a 9t (5 cell/xpeed).
July 13, 2004 at 1:28 pm #53453
the alloy pinions don’t trash the spur gear. it’s the pinions that seem to wear quickest, that’s why i tried the alloy:8ball:
July 13, 2004 at 4:16 pm #53460
Hmm.. might have to get a set of these. I’m sick of buying spur/pinion gear sets only to find that the 9t always gets worn out before everything else.
Thanks for the advice all.
July 13, 2004 at 6:26 pm #53470
When the plastic pinions wear, they deform, which ruins the spur gear gradually.
The metal pinions don’t deform, so there is basically no wear on either the spur gear or the pinion.
July 14, 2004 at 4:09 pm #53487
Kevsta; splash out the extra couple of bucks each and get stainless steel… if you get the HPI gears that is… i’ve gone through 3 nine tooth plastics already, decided enough was enough. And the meshing seems perfect…
July 14, 2004 at 8:11 pm #53497
Got my eyes on those hpi ones at the moment at $9.90 USD… but have to wait till more items of interest appear on the catalog before making the order.
July 14, 2004 at 8:38 pm #53504
12 each in the city mate… Aud $$ too… just a thought… lol
July 19, 2004 at 5:50 pm #53725
Getting a couple from the US at the moment. $15 for 2 of ’em inclusive of postage.
July 20, 2004 at 12:08 pm #53765
not a bad deal… what sizes you getting?
July 20, 2004 at 3:28 pm #53768
I’m getting 9T ones to run with x-speeds. The higher tooth ones are the same price but didn’t order those ones because I’m running without a turbo setup – read somewhere that if you use higher pinions on an x-speed you risk burning up stock fets – sort of like getting you x-speeds to push things.
July 20, 2004 at 4:20 pm #53772
I found the hpi 10 tooth s/s pinion to fit extremely well, even though the spacer is more suited to the 9 tooth. Think I will go back to the 9 to prolong the life of my fets… blackeye:
July 20, 2004 at 10:50 pm #53793
I’ve given up on the spacers and started using cardboard + paper to fine tune the position of the motor.
July 21, 2004 at 1:16 pm #53815
i use a Square alloy motor mount so stock spacers are out the window for me… on the hot Z anyways… paper, cardboard, whatever has the thickness I need
July 22, 2004 at 9:12 pm #53863
Got my pinions, fast shipping from the US – 8days only woohoo.:)
July 23, 2004 at 1:11 pm #53884
not bad mate… what sizes did you get again?
July 23, 2004 at 6:59 pm #53890
Dave, your fets will be fine with a 13-15t
July 26, 2004 at 1:36 pm #54003
sweet… now I just gotta get a motor so I can use it in that Z… i’ve only got up to 13t too I think
July 26, 2004 at 1:36 pm #54361
