1:18 ST comming soon
Home Forums 1/8, 1/10, 1/12, 1/18 – Discussion 1:18 ST comming soon
Viewing 27 reply threads
    • #12324
      merc-blue
      http://www.yourmicro.com/news/article.php?aid=14647
      check that out 1:18 AWD..comes RTR with bearings and oil shocks. also comes with duratrax stress tech warranty.
      the radio it comes with is a futaba and ESC (futaba again)… there is a 90% chance of one of these showing up in melbourne in about december :D…
      Edited by – Aaron on 22 November 2004 12:34:23
      • This topic was modified 11 years, 1 month ago by Avatar photoAaron.
    • #55388
      jamiekulhanek
      and theres also a chance of one turning up in launceston
    • #55389
      ph2t
      my madforce will still leave it for dead.
      such is the natural order of things…..
    • #55392
      bithed
      hmmm…ok…this or the Mini T or the new associated one which i have yet to see…
    • #55400
      betty.k
      i like that its center of gravity appears to be lower than most monsters out there, of any scale:8ball:
    • #55401
      merc-blue
      lol… bring it on ph2t… its pretty high vompared to a mini-t..
      i heard about the new associated thing but aint seen ne thing about it yet
    • #55402
      peteWah
      Why not get a real madforce or megaforce:smiley2:
      Now thats a serious couple of stadium trucks :smiley2:
    • #55403
      merc-blue
      umm becasue madforces and savages and emaxxes cost over a grand and then another 2 grand to get them going good. go to http://www.ausrc.com and ask how much the adverage savage has costed them
    • #55404
      peteWah
      One day maybe then A…:smiley2:
    • #55407
      PandaBear
      haha… had to go more than halfway down the page for this:
      “DTXC3307 380 Motor w/Connector”
      why wait? :p
      Tamiya TLT-1 is a bigger 1/18th and uses 540 motors!!
    • #55409
      merc-blue
      yeh but the TLT is way to high and is a rock climber monster not a AWD ST…. wont handle the same
    • #55411
      PandaBear
      heh. But 1/10 Stadium Trucks are usually 2WD not 4WD; that thing’s a weird hybrid of some sort.
      TLT-1 is geared very high, too high to be a rock climber. Out of the box I think they’ll do a fair click… not sure how well they take corners at speed but the CoG isn’t all that high really.
    • #55413
      merc-blue
      hmmm i thought they were cause they look it.. yeh i know about STS useually RWD but AWD is cool..
    • #55416
      jamiekulhanek
      merc WTF?? A Mad Force costs about $500-600 RTR…
      Add Fuel, and batteries and you’re set.
      Of course theres idiots that buy complete titanium chassis/suspension arms and spend thousands on “Bling” bits (which are stronger, but have no give in them, also adds a LOT of weight to the truck).
      Bithed, it’s the Duratrax Mini Quake…
      Not sure if i like the AE ST, its got clear plastic swing arms/shocktowers etc…
      Wills, not everybody can afford a TLT-1….
      😀 especially not me..
    • #55419
      jamiekulhanek
      More info on the DuraTrax Mini Quake..
      http://the-rc-zone.com/forums/album_pic.php?pic_id=1127FEATURES: Chassis: Composite tub style with countersunk screws
      Drive: Four wheel shaft drive
      Motor 380 motor
      Radio: 2-channel AM pistol grip made by Futaba with steering and
      throttle trim, adjustable steering rate, charge jack for optional
      NiCd batteries, battery LED and one SX100 servo for steering
      Ball bearings: Full set included –total
      Shocks: Eight oil filled body
      Gearbox: Sealed front and rear
      Tires: 2.75″ (70mm) diameter, 1.6″ (40mm) wide rubber
      Wheels: Five spoke ” ( mm) diameter, ” ( mm) wide
      Speed Control: Electronic forward and reverse with connector
      Bumpers: Front and rear black plastic with skidplates
      Suspension: Fully independent
      Camber Tie Rods: (fixed non-adjustable, adjustable)
      (Camber is how the tires sit vertically)
      Steering Tie Rods: Fixed non-adjustable,
      (Caster/Toe-in is how the tires point inward as viewed from above)
      Steering:
      Servo Saver: Included
      Warranty Period:
      INCLUDES: Duratrax Mini Quake with eight oil-filled shocks, 380 motor,
      electronic speed control, painted body, tires, foam inserts,
      wheels, — tooth pinion gear, –spur gear, instructions
      decals, 2-channel radio, eight AA batteries, NiCd battery with _
      charger
      REQUIRES:
      SPECS: VEHICLE-
      Length: 9.5″ (240mm)
      Width: 7.4″ (185mm)
      Height: 4.7″ (120mm)
      Weight: 25 oz (725g) approx.
      Edited by – jamiekulhanek on 11 September 2004 15:03:03
    • #55426
      merc-blue
      http://www.duratrax.com/cars/dtxd11.html
      here is some more info.. from duratrax.. added this morining to their site
    • #55427
      kevsta
      I want one. Are there many hot up part available for it ?
    • #55428
      jamiekulhanek
      kevsta,
      A, it doesn’t get released for about 5 weeks.
      B, it’s very potent and well equipped as standard. Just watch the videos on the DTX site.
      C, the hopups you’d be needing is maybe a quicker motor (it has a 400 size stock) and maybe an ESC to match, hopefully ProLine will make a range of tyres for it, also turnbuckles and CVD’s would add a little more tunability….
      Other things like springs/different silicone shock oil could help tailor the handling to a given surface…
      Just wait and see though, if a vehicle becomes popular, so does the aftermarket range, therefore the hopup company has found a nieche, at the moment, it ain’t popular because nobody has one…expect DTX to release alloy parts…
    • #55436
      kevsta
      Quote:
      kevsta,
      Sounds impressive. Will have to wait and see how popular it’ll be before deciding to get one, or better to get some reviews/videos of it in action.
    • #55450
      jamiekulhanek
      There ARE videos of it in action…
      http://www.duratrax.com/gallery/dtxd11-01b.mpg
      and
      http://www.duratrax.com/gallery/dtxd11-02b.mpg
      I have no doubts of the popularity, it’s great value for money. It comes 100% RTR.
      In the box there is absolutely everything you need….the downside??
      The charger is an 110v Merikan charger….
      The kit comes with:
      -Preassembled truck
      -Pre-Painted body
      -Installed ESC
      -Installed Futaba Receiver
      -Installed Futaba Servo
      -Futaba 2ch pistol Transmitter
      -DTX 400 class motor (big)
      -DTX 6 cell 7.2v 2/3A 600mah NiCad pack
      -8 AA alkaline cells for Transmitter
      -110v wall charger :dead:
      -Decals
      Thats great value for 199 US, but merc blue and myself think that the price may drop to $150US for christmas.
    • #55452
      merc-blue
      hey jamie this we should get some $$$ from DTX for all this advertising… also with the christmas martket you dont know what the exchange rate will do also casue of the election
      also how many of us dont already have a 110 – 240 transformor OR a 240VAC or 12VDC charger anyways
      Edited by – merc-blue on 14 September 2004 08:07:19
    • #55455
      kevsta
      and
      The kit comes with:
      -Preassembled truck
      -Pre-Painted body
      -Installed ESC
      -Decals
      Thats great value for $199 US, but merc blue and myself think that the price may drop to $150US for christmas.
      That video action is awesome.
      If they do drop to $150US (cross fingers)- it’ll be bloody good value. If shipping is say around $50US each to get them here – it works out to just under $300 AUD which isn’t too bad at all considering that it’s ready to run. That’s just a touch more than a kyosho mini-z monster truck when they first came out.
      If a group buy of this happens around christmas time perhaps we can get a better price.
    • #55481
      merc-blue
      yeh there may be a towerhobbies group buy if the price drops and it becomes worth it i am happy to organiseon even if there are only 3 or 4 thats will still save on postage there will probly be some other parts for 1:10 people may want to get aswell
    • #55483
      merc-blue
      http://www.ausrc.com/forum/forum_posts.asp?TID=1466&get=last#18631 the associated also looks arite and is 20 dollars cheaper from tower hobbies
    • #55491
      jamiekulhanek
      nah i’ll pass, i want that DTX MQ MT.
      kevsta, expect about 30USD or so for shipping.
    • #55582
      Racer9
      I want the DTX the RC18T and the Mini-T and everyother 1/18 scale vehicle (except maybe the Micro RS4)
    • #55585
      jamiekulhanek
      Mini T needs too much $$ to make it as good as the others.
      For me its a toss up between the other 2….but bugger it, im getting an Associated RC10GT Truck.
    • #55795
      AdamC
      Grafix from one18th.com has made a shaft driven 4wd 1/18th stadium truck based on the X-ray M18
      http://www.one18th.com/projects/MT18.php
      He’s not saying much about what parts he’s used, its being published in a magazine. sounds like this thing will have alot of potential though.
