40Mhz Mini-Z?
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › 40Mhz Mini-Z?
- This topic has 6 replies, 4 voices, and was last updated 21 years, 6 months ago by
oldtamiyaphile.
July 3, 2004 at 11:53 pm #12237
What would be required to convert a MZ to 40Mhz operation? I ve got a really nice 40Mhz AM TX, and it s probably easier to convert my cars than the TX. I know I ll need a new inductor, how do I work out the value and what else do I need?
July 3, 2004 at 11:55 pm #53126
this is a question for microamps or ph2t
July 4, 2004 at 2:32 am #53129
OTP. it would help if you had full schematics of the RX in the car. First thing to do is chuck a 40mhz crystal into the RX and see if it works.
Given that the RX is a crystal controlled device I believe the changes that would need to be made couldn’t just be limited to a component or two. Given that the RX is prolly setup as a PLL receiver it would be tricky to mod to suit 40mhz.
But then again, I prolly also have no idea…….
July 4, 2004 at 2:39 pm #53157
Mini-Z 40MHz is FM, and it is design for KO EX10 FM or Kyosho FM control (EX5) only, it can not use other FM control. It is MR-01 and MR-02 type. It is more detail in Kyosho web-site.
July 4, 2004 at 6:49 pm #53163
Thanks, I’d would rather not give in to Microsoft style incompatibility yet again. I miss the days when as long as you had the right channel everything worked with everything else.
Iwaver: Works with KT-5 but not KT-2, KT-5 does not have servo reverse so you have to mod the car. Works with 2PL
Mini-Z: Seems to work with everything.
Epoch: Works with KT-2, not 2PL.
July 4, 2004 at 8:38 pm #53168
otp, do you have info/links on the type of radios use in standard hobby RF ?? you know, encoding standards, rx/tx types, etc, etc…. that sorta stuff…..
thanks,
July 4, 2004 at 10:58 pm #53172
These guys do some freq conversion work:
http://www.vantec.com/applications.htm
and
http://www.phoenixmp.com/articles/rc-systems.htm
It’s a start…no real good info though, I’m sure you know most of that already.
Edited by – oldtamiyaphile on 04 July 2004 19:01:26
