ABC Switch on Booster controller
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › ABC Switch on Booster controller
- This topic has 10 replies, 3 voices, and was last updated 23 years, 7 months ago by
avoid the noid.
August 10, 2002 at 4:23 pm #9242
Am i right in thinking this switch is for :
A : Controlling NORMAL (nonbooster) cars
B : Using in BOOST MODE
C : Running in FULL SPEED mode for booster car. -
August 10, 2002 at 10:40 pm #15181
yeah that seems right, but you do know that in A mode that the controls for forward and reverse are switched.
so if you press forward your going backwards.
August 11, 2002 at 12:36 am #15185
This isn’t necessarily true. I’ve not seen a 4 channel controller where the forward and backward actions are reversed… You might have a defective controller.
Rob
August 11, 2002 at 4:41 am #15187
The OEM Bits have the forward and backwards reversed. The 4 Channel controller will control other Tomy Bit CharGs fine.
August 11, 2002 at 9:50 am #15190
oh haha.. that might be it then cause i have a oem bensu, and a booster machine set
August 12, 2002 at 8:49 am #15211
on a different note, does anyone know what the blue button on the top right hand side of the 4 band controller is for? Surely it must do something?
August 12, 2002 at 4:11 pm #15224
It`s the booster button :smiley13:
August 12, 2002 at 4:45 pm #15225
Booster Button for Booster Bits
August 12, 2002 at 5:11 pm #15226
how do you mean? I thought that to put the boost on you have to switch the ABC switch at the back… are you saying you can just press that button instead…??
August 12, 2002 at 6:46 pm #15228
That’s the whole point of the booster. It’s a 2-speed bit. switch the ABC selector to B to enable the boost function. Then the car goes slow until you press the button.
August 12, 2002 at 7:52 pm #15230
when im racing on my track against friends i have my booster set in B mode that way on turns i can release the “turbo” button and take the turns slowly and not spin out like some of my friends do adn then on the straight aways i hit the switch and im off so yea it does have a purpose
