about auldey race win 1/16
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Tin Car, Palm Runner and similar › about auldey race win 1/16
- This topic has 26 replies, 5 voices, and was last updated 22 years, 11 months ago by
Pork_Hunt.
August 31, 2003 at 1:58 am #11401
has anyone tried playing with an auldey race win cars
and have tried upgrading it with relays
if you do,can i ask for a diagram -
August 31, 2003 at 1:21 pm #36211
i have got the diagram thing some were on a pice of papper looking in upgrading myne soon when i have some time
September 1, 2003 at 12:11 am #36223
cool
can you send me one plsss
so that i can try upgrading my race winhave you tried using battery packs for your race win?
September 1, 2003 at 1:33 am #36225
you’d need 2 seperate battery packs if you still want turbo to work, i personally didn’t think it was worth the stuffing around
September 1, 2003 at 11:03 am #36228
i tell you waht i like with the race win u can mod it and hide all the mods with a race-tin after you do heaps of mods u got batary hanging on the roof and other crap race-win you can have it all under the cars body
September 2, 2003 at 5:32 pm #35511
The race-win has the worst tyres ever tho
September 2, 2003 at 5:32 pm #35808
September 4, 2003 at 12:43 am #35537
yup they are when they are in stock
but if you have upgraded into bearing it would be a blast. 😀what i dont like about race win is the buzzing sound it makes when turning 👿
September 4, 2003 at 12:43 am #35834
September 7, 2003 at 3:13 am #35301
hey guys help me out with my predicament
its about the relay thingy…:D:D
can you send me diagrams plssss :clown: -
September 7, 2003 at 6:40 am #35303
what batteries you running that cause the buzzing???
relay diagram:
Do you have different tyres for yours?
Edited by – Pork_Hunt on 07 September 2003 02:49:43
September 9, 2003 at 12:49 am #35343
im using gp 2000
im presently using my stock tyres
ill be upgrading to bearing tyres soonhow about a 6pin 5v relay setup diagram?
coz im having a problem on purchasing a 5pin 5v or 6v relay.:D -
September 9, 2003 at 3:08 am #35346
5 and 6 pin relays are the same, the 5th and 6th pins are connected internally. I haven’t tried using 5volt relays on a race-win, and i guess they would work (1.2 * 4 = 4.8v) but i do know that jaycar 6v 6pin relays work a treat.
September 9, 2003 at 1:51 pm #35355
oh ic :approve:
what are you using now?
:smiley16:
September 14, 2003 at 9:43 pm #35099
how’de just got my auldey race win car lat weekend (200sx) and bought my misses a supra the sx has already had a respray (Yellow) and modified motor (from 100 down to 45 Turns)
also the 2 batterys (deepest into the bat box are the turbo batterys. so if you want a faster turbo connect more batters in series to these. the relay mod willnot do much inless you have a verry low turn motor which draws more current to turn and cannot draw it throgh the circuit board
theres a site (&shop) in adelaide http://www.rczone.com.au which i think has all the upgades (tyres, motors parts etc.
:8ball: -
September 15, 2003 at 5:14 am #34346
I couldn’t find any parts listed on the website…?
I was kinda disappointed with my relay mod, but it does mean if I do get my grubby mitts on a rediculously fast motor, I can use it. -
September 15, 2003 at 2:18 pm #33993
do these things use 130 style motors?
September 16, 2003 at 3:30 am #33976
i think there a bit bigger like mid 200 the relays only stop the resistance of the circuit board by taking power straight from the batterys it wont let that much more volts through though but alot more amps will be able to be drawn
September 17, 2003 at 2:12 am #33703
how many batteries have you added on your setup?
September 19, 2003 at 3:02 am #33954
me none yet i hvae the normal 4 for the normal spped and the 2 extras for the turbo i might ad another 2 on the turbo circut i cant seem to charge the batterys i bought in the charger i bought the charger is one of those delta-v comuter chargers but the thing only seems to be charging at peak rate for over 12 hours now and the batters are still flat i might have to take it back
September 21, 2003 at 1:33 am #33559
have you tried upgrading your race win with relays
September 21, 2003 at 2:13 am #33561
i have tried upgrading my win with a 3 5v relay setup. the problem im having is when im into turbo mode and release it and the cars slows down it still keeps on moving.
what do you think the problem is:sad: -
September 25, 2003 at 3:23 am #32870
i compleated the turbo mod on the week end and my car went a bit better im trying the 4x5vrelay setup but after my last message about the battery+charger problem i have discovered that its not the batterys or charger but my car well i thought it was the motor i re wound it to 45turn and it use to go insainly fast with little load but now even with no load it just spins at about 200 rpm im guessing and gets verry hot so i took out my relays and motor and put the stock motor back in. this was fine untill i lost reverse about 5 mins later then the turbo started to pulse on and off when i tried to use it
so i took all the transistors out of the circut board -
September 27, 2003 at 1:45 am #31727
i have heard that someone with a 3 6v relay negative contact had added batteries aside from the stock batteries.
do you know anything about this negative contact connection?
and how do we add batteries with a relay setup?
any help would greatly be appriciated :clown:
September 27, 2003 at 1:47 am #31659Quote:me none yet i hvae the normal 4 for the normal spped and the 2 extras for the turbo i might ad another 2 on the turbo circut i cant seem to charge the batterys i bought in the charger i bought the charger is one of those delta-v comuter chargers but the thing only seems to be charging at peak rate for over 12 hours now and the batters are still flat i might have to take it back
how can we add batteries?
where do you connect it?:D -
September 27, 2003 at 5:27 am #39243
Depends when you want the power.
It would be easiest to add them in series with the turbo pod/thingy. Otherwise, I dunno how you would do it without having to put higher voltage relays in. If you were using the
http://www.tinracing.com/Diagrampages/diagram16.htm
diagram, cut the green wire… Put a battery holder inline with it (check it first but i believe it would be -ive close to the pod, +ive close to the relay, but CHECK first, no good killing batteries). Dunno what the motors’ll take, but I’d say no more than 12v including main batteries (ie, no more than 2-4 additional batteries).
Personally i don’t think adding batteries is gunna make THAT much difference, mine just has a straight relay mod, and I have replaced the motor with a quicker-feeling Jaycar one and even on reasonably grippy surfaces the tyres slip around. -
September 28, 2003 at 10:23 pm #31303
so your using this diagram now
http://www.tinracing.com/Diagrampages/diagram16.htm?anyway thanks for the help
:smiley2:
