alloy FRONT damper mount is finally available
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Discussion › alloy FRONT damper mount is finally available
- This topic has 21 replies, 9 voices, and was last updated 21 years, 9 months ago by
jamiekulhanek.
June 4, 2004 at 3:07 am #12180
and it s about bloody time, I have gone through 3 already….
it ain t cheap, $16.90USD. someone s sure gonna make their money on this lil baby….
http://www.rcmart.com/catalog/product_info.php?cPath=144_21_512&products_id=8290
(happy)ph2t.
June 4, 2004 at 7:36 am #52014
no wonder toyeast was sellin standard dampners for 3 bucks each!
might get that baby when its a bit cheaper or i have broken all my dampners which ever comes first
June 4, 2004 at 1:07 pm #52021
when they come out in silver i’ll get the front & rear… yeah, they’re abit pricey eh?
June 4, 2004 at 1:28 pm #52026
well, I bought the front and rear on ebay a few days ago, and then this pops up at rcmart. they were a few $$ cheaper but still, at the end of the day it’s costing me $33USD inc shipping to get ’em here.
June 5, 2004 at 5:51 am #52058
Build your own 😀
June 7, 2004 at 1:40 pm #52101
ever run a CAD program OTP? What you speak of is not impossible (unless you’ve never done it before…) but the ground work needed to pump em out is huge. Lets just say I understand why these aluminium parts are so expensive…
June 7, 2004 at 6:00 pm #52116
Yes, but I’ve reverted back to pencil and paper. It’s a lot quicker for me since I don’t have any CAM machinery anyway.
My OL chassis is about 1/4 done. It’s about an inch longer than stock for this project:
http://www.wegotu.com/forums/view_topic.php?id=1604&forum_id=20
Once that’s done there are MOL, 4wd OL, and possibly a bus chassis to build.
Although I have to say, I don’t think $17 is all that much for any alloy damper mount (not cheap, but not unreasonable either). See how far US$17 gets you in an Aussie hobby shop.
June 7, 2004 at 6:19 pm #52119
beats forking out again and again for plastic parts. Once alloy is in, end of breakage. There, anyway…
June 7, 2004 at 6:34 pm #52122
I think some ausmicro.com’ers will differ 😯
June 7, 2004 at 6:44 pm #52126
hey normal plastic shock stay sets are cheeeep now days.
but alloy looks cool.
June 7, 2004 at 6:49 pm #52127
like I said… it will decrease/stop breakage thee, but will no doubt create a new weak spot…
think I prefer the stock now that I think of it… -
June 7, 2004 at 8:23 pm #52135
my churning rate sofar:
new broken front damper mounts: 3
re-broken front mounts(after glued): 6-7 timesgot alloy front damper mount (OL bastard son version).
Now….
new busted front servo case: 3
re-busted front servo case: 5 timesnow getting OL alloy servo case, the top half will fit….. 🙂
this is the general casualty list:
busted oil shock shaft
busted front right steering knuckle
severly cracked rear rims
front rims cracked
broken servo wires, replaced with own, better now
fried 3 seperate FET stacks
fried stock FETS
and I won’t even talk about the shell……ph2t.
June 7, 2004 at 9:25 pm #52137
oh yeh not a bad list…. heheheh my x mod has run only for a total of 8 minuets and has destroyed:
3 frount knuckles
3 set of fetts (one stock. 2 single stack)
about 8 wheel nuts.
one set of brushes (were abit pre worn)
2 shocks
5 sets of inductors (bloddy antenar kept coming unscrewed and hiting misc parts (either battery or pcb)not bad for 8 minuets heehehehehe
June 7, 2004 at 10:13 pm #52139
How do you drive merc blue? demolation derby or something?
How do you smash so many things in 8minutes?
Looks like another L-plater,LOL! -
June 7, 2004 at 10:45 pm #52141
My z: 1st servo gear x5, plastic h plate x1, carbon fibre x2, 6×2 fet stack and tamiya plasma dash, front bulkhead, bulkhead mount, shell x2, stock diff spur, 2 tyre sets, 3 wheelnut sets…Ah what a waste
June 8, 2004 at 12:34 pm #52147
i drive like a grandma.. but when i do let it go and it crashes its ALL over
June 8, 2004 at 5:39 pm #52163
…im sure that piece will do the job but it looks like crap 🙁 I REALLY need to some work on the world-saving M-PLATE 😉
June 8, 2004 at 8:34 pm #52172
what’s an M-Plate? > O-Plate?
novin
June 8, 2004 at 8:36 pm #52173
jamie what did you do to your PD and your FETS?
June 9, 2004 at 1:01 pm #52184
Stu/ Nov; O plates are an alternative to H plates, a lot stiffer, hence less likely to snap. M plate? Well, i’ll tell you when I find out but I bet it’s a Monster thing…
June 10, 2004 at 2:21 am #52242
Well, sales must of been good cause rcmart is now out of stock on the front damper mount.
So I hope all you madforce owners out there got your order in soon enough!
June 10, 2004 at 3:25 am #52243Quote:jamie what did you do to your PD and your FETS?
Well, i left a shim out of the motor mount, which made the gear mesh too tight and overloaded the motor, which made it get hot enough to burn the enamell wire on the armature and make a dead short. The FETs couldn’t take this load at all and blew. There was a trail o smoke coming from under the car when it died.
