An idea to improve steering
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › An idea to improve steering
- This topic has 20 replies, 7 voices, and was last updated 22 years, 2 months ago by
June 22, 2003 at 1:42 pm #10977
Fellas, I was tinkin’ the other day about the steering coils in the front assembly and what could you do to make the steering stonger. With the advent of mosfet, daul cells, and other nice things that make bits go really fast the steering assembly needs tighter, more refined control than ever. I’ve expirmented with doubling up the steering spring on a dual cell and this does help. With the extra voltage going to the coils the extra spring doesn’t kill the steering all together…
But what do you do with a steering assembly on a single celled bit that is pretty weak? If anything I’ve noticed that my Lxx clone has a way stronger steering pull than the legit TOMY’s.
The idea came to me to put some metal in the middle hole in the steering coil that is a donut. This should increase the coils magnetism when it has current going through it and improve the strength of the steering. Just an idea at the ‘mo. Gotta do some tests to see it this idea would really work.
What have you kids done to improve the steering?
June 22, 2003 at 4:53 pm #26389
ph2t, my guess is that one of two things will happen……
1. The steering magnet will be attracted to the steel center in the steering magnet and will lock on. and / or…2. when the metal in the center of the steering coil becomes magnetised, it will hold residual magnetism and cause the steering to lock on in one direction or the other.
(Sorry, for being such a wet blanket):sad:The rare earth magnet used for the steering in these things is so sensitive, that the steering coils need to be ferrous free in order for the steering magnet to be able to return to the center after power to the steering coil is turned off.
Good idea though, keep them coming.
June 22, 2003 at 4:55 pm #26390
Re steering improvement, an N channel FET replacement of the steering transistors makes the steering stronger.
Edited by – micro_Amps on 22 June 2003 18:34:57
June 22, 2003 at 6:49 pm #26392Quote:ph2t, my guess is that one of two things will happen……
1. The steering magnet will be attracted to the steel center in the steering magnet and will lock on. and / or…Sh1t, I didn’t even think of that!
Quote:Re steering improvement, an N channel FET replacement of the steering transistors makes the steering ultra strong.Yeah I was going to try that, what increase in strength did you see? Could the steering handle an extra centering spring now you reakon?
June 22, 2003 at 7:41 pm #26323
you could also wind your own steering coils….
June 22, 2003 at 10:42 pm #26330
ph2t the single cell fet modded steering modded car I have does have 2 steering springs, and it runs dead straight and isnt phased by minor grooves in the floor either so it is an improvement. The coils have trouble pushing against the springs when the wheels are off the ground, but when it is running on the floor is steers just like normal. The main difference is that it holds a straight line better.
You can take out the steering spring and tighten the loop a little so the spring is stronger. Or bend the ‘legs’ of the spring so it pushes harder.
GT-ahhs idea of winding lower resistance steering coils would be the go, I have seen an instruction on the net somewhere but I havent tried it yet.
You could then set them up to be as strong as you like.
June 23, 2003 at 4:21 am #26343
well. guys, i need some of those springs(i need at least two extra ones for my dual cell cars)anyone have some spares?. and i can’t find the peoper material to make my own springs.which materials should i use?
June 23, 2003 at 11:58 am #26350
RCmod sell them but they aint cheap, and it includes the magnet. I’d love to be able to find spring wire thin enough to make my own.
Any body have any ideas ?
June 23, 2003 at 1:03 pm #26352
I’m thinkin’ guitar string again……:smiley2:
June 23, 2003 at 1:13 pm #26353
Does it come THAT thin??
I’ve looked at piano wire but even the thinnest is still way thicker than the return spring.
June 23, 2003 at 1:23 pm #26354
Yeah piano wire is way too thick. I raided my old man’s piano shop on the weekend and sussed out all the gauges. Good for cutting cheese though, lol!
leonli17, try toyeast.com they have repair parts, might be cheaper than rcmod.com.
Cheers,
June 23, 2003 at 5:38 pm #26369Quote:you could also wind your own steering coils….
LOL u must have waaaay too much spare time.
June 23, 2003 at 7:54 pm #26291
I went to the local guitar shop and bought some fine guitar wire, it is very very very thin, but still thicker than the return spring wire. It might work tho, I’ll give it a try.
Another good idea ph2t, are you just full of them or what.:D
June 23, 2003 at 8:13 pm #26298Quote:Another good idea ph2t, are you just full of them or what.:D
:)uASome people would argue that I’m full of #%^$^&
:p
June 24, 2003 at 1:30 am #26208
you know what they say, there’s a thin line between genius and insanity.
We just have to work out which side we are on.
June 24, 2003 at 1:42 am #26209
guitar strings do work im fairly sure, but yeah I used a spring from an old floppy disk, it needed some tweaking/cutting tho
June 24, 2003 at 3:11 am #26110
I’ll say i am in between genius and insanity.
i’ll try to find some in toyeast. -
June 24, 2003 at 3:12 am #26112
i mean the springs, not insanity!!!
July 14, 2003 at 1:06 am #23030
I think there MIGHT be another problem with a stronger magnet and steering coil.:
In the motor their is a magntic coil that rotates and blaah, blaah, blaah…. All im saying is that MAYBE a stronger magnet could de magnetise some of the motor parts. Meaning the motor might not run as well over a long period of time
Im just guessing but i dont know for sure
July 23, 2003 at 12:40 am #22923
There is some kinda magent you can get at QFM called rare magnets or something like that They are about 50 times stronger than a normal bit magnet
July 24, 2003 at 1:48 pm #22018
And probably draw 50 times the current…….
