BDrift
I’ve done the CAT5 mod to my cars only – NOT the controller. The length of all the antennae is 70mm (from the antenna clip to the tip) except for the 57MHz car, which is fitted with a 90mm antenna.
Excellent increase in jitter-free range.
But, as Prabbit advised, make sure you get construction-grade CAT5 – cutting a section of the multi-core stuff from the patch lead at the back of your PC will not be very effective (oh…. and you’ll probably lose some of your network connections, too :smiley2:)
Derek
