Ball Diff Install
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Ball Diff Install
- This topic has 17 replies, 9 voices, and was last updated 21 years, 6 months ago by
dgs73.
August 16, 2004 at 1:06 am #12296
I picked up a ball differential that came without install direction (of course :/). In the package are two soft rubber O-rings. What is the proper install procedure for the O-rings? Being of a soft rubber type, they appear to be for tension or torque adjustment rather than just spacers as with a metal shim. And what shaft adjustments or positioning, if any, are correct for proper function?
Thanks,
N-Hawk -
August 16, 2004 at 1:09 am #54855
The “o” rings go between the thumbwheel and left diff plate, it adjusts the slip/action of the diff so you can adjust it to give good traction on any surface
August 16, 2004 at 4:48 am #54860
Thank you! And what size is that darned allen screw? My smallest is too large. :/
N-Hawk
August 16, 2004 at 1:07 pm #54861
that grub screw is 2mm… try a jewellers screwdriver set, that’s one place you’ll get a allen key that small, or if your local hardware store has em singly, mya be your best bet…:smiley2:
August 16, 2004 at 2:30 pm #54869
Thank you again. Finally got it with a 1.5 from my jewelers set and a pair of visegrips — it was stuck! LOL
August 16, 2004 at 2:57 pm #54871
Only use one O ring dude….. and give us a report on your sucess with the diff, if you have any problems, just give one of us a holla…
August 16, 2004 at 4:57 pm #54873
i lost the grub screw from my gpm ball diff and i got some replacements from a r/c plane shop.
only cost me $1.50 for three of them but they are a bit too long for the hole.
when adjusting/tightening the diff whats the best setting for different surfaces? i think i’m running mine a bit to loose at the moment.
August 16, 2004 at 7:52 pm #54877
Well, this was not a good day for much of anything — especially not to be working on the new diff!!
Got to breaking down the new diff to install the delrin gear and ….. the danged little c-clamp decided to take a prolonged vacation to parts unknown and to never be seen again. :dead: Guess I’ll spend a good deal of the next couple days scouring the local hardware stores to try to find a replacement. I already know they don’t carry metric screws or nuts that small. :8ball: -
August 16, 2004 at 8:23 pm #54878Quote:Well, this was not a good day for much of anything — especially not to be working on the new diff!!
Got to breaking down the new diff to install the delrin gear and ….. the danged little c-clamp decided to take a prolonged vacation to parts unknown and to never be seen again. :dead: Guess I’ll spend a good deal of the next couple days scouring the local hardware stores to try to find a replacement. I already know they don’t carry metric screws or nuts that small. :8ball:I don’t think you’ll find them at hardware shops your best bet would be to try a local rc hobby store. I know tamiya carry them in bags of 10 and should only set you back a couple of dollars.
August 16, 2004 at 8:35 pm #54880
those c-clips give me the utter s***s… my carpet in my room has eaten at least five of the little buggers… so easy to lose as they fly off when being removed:angry:
August 16, 2004 at 8:58 pm #54881
Thats why i buy about 10 at a time from fastener stores….
The pilot shaft on the engine of my Nitro 1/10 has a c clip on the end, and if it comes off often the roller bearing comes out too and zooms off at a million miles an hour into a big patch of vegetation…..$22 just for the little roller bearing hurts….
August 16, 2004 at 9:00 pm #54882
funny how the smallest parts fly off into the largest areas of grass/shag carpet/etc…
August 16, 2004 at 9:50 pm #54884
Try a big-ass magnet 🙂
Won’t work on all parts but I find it handy on occasion, enough so that I’m considering making a rare-earth magnet “broom” 🙂 -
August 16, 2004 at 11:04 pm #54885
some parts such as stainless steel and non ferrous metals/composites are not attacted to magnets….
August 17, 2004 at 1:09 am #54887
fortunately spring steel is magnetically attractive. i always have a big magnet right on the diff when removing the e clip. you should have one on your old stock diff (if you have one).
jamie told me to set your diff up so it slips just a little on take off. like a poor mans traction control, have it so the diff slips before the tyres do.:8ball: -
August 17, 2004 at 8:21 pm #54916
They don’t call the “jesus clips” for nothing 😉
You can also buy proper plier for handling them that reduces the loss factor to a much more sane rate 😉
August 17, 2004 at 11:57 pm #54926
they call em “jesus clips” cause you say Jesus Fucking Christ where the fuck did that fucker fly off to!
i use a noticeboard pin to get em off, wouldnt mind buying a few spare to make sure i never lose em, same with grub things!
Edited by – TallduDe on 17 August 2004 19:59:18
August 23, 2004 at 1:17 pm #55003Quote:They don’t call the “jesus clips” for nothing 😉
looks like another trip to Jaycar is in order…:smiley2:
