Batteries dying ultra quick?!?!?!?
Home › Forums › Mini-Z, Mini-X, X-Mods and other Mini-Scale › Mini-Z, Mini-X, X-Mods – Technical › Batteries dying ultra quick?!?!?!?
- This topic has 7 replies, 3 voices, and was last updated 21 years, 1 month ago by
January 11, 2005 at 3:18 am #12499
Hey Guys/Gals
ok so hears the deal
i took my Iwaver 02 apart to adjust the steering pot so my iwaver wouldnt run in circles all the time, which is fine except for the fact that i broke the wires to my motor(at the solder joints). I also put wax on the steering pot to stop it from moving, but i got it on other parts of the circuit board…
I then got an engineering friend to resolder them back into place. however the negative wire soldering looks a bit dodgy?
my questions are:
does it matter if wax is on other parts of the PCB??
what could be causing the batteries to drain so quickly(within 15 seconds??? -
January 11, 2005 at 3:25 am #57924
1. Dont worry about the wax on the pcb, it wont cause shorts, it may give you some grief on the battery contacts if it gets on them, try and remove as much as possible.
2. You have a dead short in the battery circuit somewhere. Dont put batteries back in there until you sort out the problem.Are any parts getting warm when the batteries are running down so quickly?
:)uA
January 11, 2005 at 3:38 am #57925
How do i find where the dead short in the battery circuit???
what should i do???
January 11, 2005 at 3:43 am #57926
is any part of the battery circuit near where the antenna goes?!?!?
I had to have my friend re solder that too.
January 11, 2005 at 3:49 am #57927
might sound obvious but are your batteries charged to begin with? if you can put up some close-up pics of the pcb here it may help.
a dead short means the + is directly connecting to the – somewhere before entering the pcb, or somewhere on it. messy soldering is ok provided it’s not making contact with other parts of the pcb.:8ball: -
January 11, 2005 at 3:54 am #57928
Yes the batteries were charged like a week ago…
how quickly do NIMH batteries lose their charge??yeh sure ill post up a close up pic of the PCB, just be a couple of minutes
January 11, 2005 at 4:10 am #57929
Ok the photo of my PCB is in my gallery
Here —-> http://www.ausmicro.com/gallery_display.asp?user=5871
January 11, 2005 at 4:33 am #57930
your pcb is slightly different to mine so i can’t really comment. but on mine the main + and – wires are the other way around.:8ball:
