Battery doesn’t last long
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Battery doesn’t last long
- This topic has 12 replies, 7 voices, and was last updated 22 years, 11 months ago by
micro_Amps.
February 12, 2003 at 10:13 pm #10889
I got this battery from Jaycar.. It’s a little longer than the standard Bit bat, but it fits okay. It’s 3.6Volts too, so the car’s f****** fast!! But it only lasts about two minutes. I’m charging it on a 4 battery charger.
Is it because it’s only 43 maH ???
February 12, 2003 at 11:58 pm #41260
Try charging for longer until the battery starts to warm up a little, and maybe at a slightly higher voltage, say 7.5 – 9v for about 90 secs but watch the temp.
Having said that I’m gonna get me one of these ASAP 🙂 Thanks for spotting it and posting it.
uA -
February 13, 2003 at 12:05 am #41258
Anyway, what I meant to post is that, yes, the 2 mins is because it is a smaller capacity battery. You are back to the original setup of a 50mAH battery, just now you have a higher voltage. So you go fast for the same amount of time as a standard battery….about 2 mins.
Bing **(light goes on in uA’s head)**
You could however do a ripper dual batt bit mod and have 3.6v at 86mAH which might last you 5 – 10 mins when fully charged, and it would run like a triple bat bit. It’d be a rocket
February 13, 2003 at 1:58 am #41257
yeah i saw those at jaycar and was wondering if they’d work… guess gtvolv beat me too it…:D
http://gtahh.web1000.com/
February 13, 2003 at 3:15 pm #41242
Thanks for the info guys…
I have been charging it till its warm (~5min), I might try a higher voltage.
For a dual bat with 86maH, they’d have to be wired in parralel yeah?
February 13, 2003 at 3:36 pm #41241
I wonder if battery world would be able to supply a higher mah battery the same size??
DaveF! 👿
February 13, 2003 at 4:04 pm #41236
iv had that battery for some time, it flies but only for a very short time (good drag battery). But doing a dual batt to get 86MAH should work nicely, keep us posted !
57MHZ 2.6 Booster Trueno
February 13, 2003 at 4:20 pm #41232
February 13, 2003 at 6:44 pm #41224
yeah if you wire in parallel it would increase the current..series = voltage
February 13, 2003 at 11:27 pm #41198
I’ve just put one into my booster. Goes ok, fast but doesnt last all that long. I guess Ive grown used to the 150mAH NiMH batteries.The motor and pcb warm up a fair bit cranking out 3.6V. Might need a few more runs to develop its full capacity.
BTW I charged at 6V for about 3 mins, until just toasty warm. -
March 18, 2003 at 4:08 am #36918
Can someone help me out. How do I charge this battary? Do I need to cut the charger thing from my remote and connect it to a 4 X AA charger.
March 18, 2003 at 3:13 pm #36895
Yeah, you need to get the charging “clip” thing off the remote (cut or unsolder the wires), and connect it to a 4-battery holder. I think the QFM website has instructions.
March 18, 2003 at 4:46 pm #36901
make sure the batteries are in series, and the polarity remains the same…
