BCG brain
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › BCG brain
- This topic has 6 replies, 4 voices, and was last updated 22 years, 5 months ago by
trash.
September 20, 2003 at 6:11 pm #11362
I was having a bit of a peak at a micro RX board yesterday and I was pondering what the main chip is on it. Has anybody come across the
chip part number or even a company that just makes the boards, or even
the circuit diagram for them. (wishing too hard there).
They all look generic. Either 1 motor and one servo for cars or
two motor control for things like tanks and boats.
Won’t be long before 3 and four channel units start to appear.
The added circuitry isn’t much extra. -
September 20, 2003 at 11:05 pm #33557
Trash,
the early Tomy BCG cars were all based on the Rxc2 and Txc2 chipset combination. These had a booster function option, all of the early BCGs used the Rx2c chips including the early booster cars with the boost option enabled on the Rx pcb. But the xc2 chipset only has 4 functions. Later versions used the Rx6c/Tx6c chipset. All of the later version Tomy booster cars are using the Rx6c receiver pcb.
The R/Tx6c chipset has 6 functions, L/R/F/B/F1/F2, there are also Rx/Tx5, 7 and 9 chipsets with up to 9 seperate functions.
The tanks use a fully optioned Rx6c chipset that has all 6 functions operating, L/R/F/B/turretL/turretR.
The super BCGs are using a PT (Pericom Technologies) chipset with reversed logic, this is a pain and is the reason the supers ‘keep going’ when they go out of range instead of switching off.
If you do a net search for the Rx2c schematic I am sure you will find it. A 49MHz MS circuit diagram is also on the net somewhere.
The newer PT chipsets are not available on the net (afaik).
[:)uA] -
September 22, 2003 at 5:48 pm #32898
uA when you said the boosters use the rx6c chip that has l/r f/b f1/f2, does that mean there is room for three forward levels of power or should it read l/r f/b f1/b1?
and with your understanding of the super bcg chip would it be possible to have multiple levels of boost?
September 22, 2003 at 6:11 pm #32901
Sorry, the F1/F2 I refer to is function 1 and function 2 (as listed on the data sheet)
Just to clarify, he Rx6c chip has the following functions
forward – unboosted
forward – boosted
backwards – unboosted
backwards – boosted
left
right
extra function 1
extra function 2
Yes I suppose that extra function 1 and 2 could be used as extra forward speed functions if the circuitry was right. This is for 1st generation BCGs.The super BCGs dont have the boost at all and the PT chip set is a real pain in the arse to mod too.
So no, forget about extra speeds on the current range of super BCGs. I am yet to see a circuit or data sheet for the ‘super’ circuits.
September 22, 2003 at 10:35 pm #39276
excellent … thanks for that.
September 28, 2003 at 7:57 pm #31291
thanx for the info…
September 28, 2003 at 8:06 pm #31295
Here’s some links to some threads that have ALL the datasheets you’ll ever need:
http://www.bitpimps.lixlink.com/pages/phpForum/viewtopic.php?t=264
