bit diff!!!!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › bit diff!!!!
- This topic has 16 replies, 3 voices, and was last updated 22 years, 11 months ago by
z-beam.
October 24, 2002 at 7:45 am #9392
last night iwas racing one of my bits when i realised my car was accellerating funny, slowly picking up speed on the satin varnished table. i thought it was doing burn outs when it dawned in me ” you arnt loosing it ” i found the reason, the cog had loosened on the axle so if u hold the car down the axle spins but not the wheels. couldnt make it last though, the top speed is appaling so i fixed the accidental discovery with a drop of super glue. if you like drift racing u should have a go and tell me what u think.
October 24, 2002 at 10:40 am #15931Quote:Originally posted by z-beam on 24October2002
Like, you mean the SPUR GEAR came loose and is spinning on the axle – thus the wheels don’t move, ‘cos the axle won’t be moving either.
Or else your wheels will just fall off…?
October 24, 2002 at 11:04 am #15934
yeah but not toloose. i recon if you could control the slip factor by using some substance that is smooth untill u aply a certain amount friction u might get good results.note that the spur gear loosened to spining on the axle but it did not slide off its position
October 24, 2002 at 11:23 am #15936
In big RC terms that’s called a “slipper clutch”. Its there mainly to protect your transmission gears (eg buggy jumping) but on a BCG its pretty useless.
Ball diffs should never be set loose enough to slip, you’ll flat-spot the balls and groove the rings.
Why do you want your bit driving around like its got a busted clutch anyway?? :smiley1:
October 24, 2002 at 11:46 am #15941
already said that i used superglue to stick it in place.
a rev limiter is what i need. the effect i was after was like traction control
October 24, 2002 at 12:25 pm #15944
Haha, I just picked up a Bit Racer tyre set. Stuck the set’s soft in front and hard on the back and it was DRIFT CITY!!
Ya, cannot use the kit tyres in front, they are too sticky and it’ll just do donuts.
Can see that the rears are slipping all the time too, whilst running on hardwood surface. Car goes a little slower than with sticky kit tyres all round.
October 24, 2002 at 2:48 pm #15962
The difflock has failed on one of my wheels, but the wheel wont come off the axle…..
October 24, 2002 at 7:00 pm #15995
u know what i mean jamie. is it the gear side or not?
October 25, 2002 at 9:18 am #16026
Yep its the gear side…how did it happen…its not like these cars have any torque.
October 25, 2002 at 10:06 am #16032Quote:Originally posted by jamiekulhanek on 24October2002
You’re trying to fix it or trying to pull it apart for spares?
To fix, why not just glue the wheel to the gear?
October 25, 2002 at 10:13 am #16033
Nah the gear and wheel is stuck together, and the axle is free to turn inside the hub thingy. if i just put a drop of glue on it, it won’t hold for long as the axle is so thin and has very little surface area.
October 25, 2002 at 10:28 am #16035
Ya, you’ll have to yank it out (nothing holds it in, just friction) then scuff it up. I’d scratch some lines on the axle then try use epoxy to glue the whole thing back.
Superglue does not stick to metals well.
October 25, 2002 at 11:12 am #16042
Yeah, i was worried that it might have barbs on it or something, i have some 24 hr industrial strength epoxy that i’ll use, and ill roughen up the end with fine sandpaper.
October 25, 2002 at 11:17 am #16044
No, don’t use sandpaper – the scratch will be too fine. You want to deeply scratch the axle so that it has splines in it; I’d use a stanley knife to draw a few lines just on that end bit.
October 26, 2002 at 7:33 am #16073
to make my hotswaps i had to cut the wheels off an orange axle and unfortunatly there are ridges anong the axle. pull that wheel off and i assure you it will be a bitch 4 life. the gear was made on the axle so you could use a highly viscous superglue like zzap. in that confined space it’d work good
October 28, 2002 at 11:23 am #16239
I thought I’d investigate futher and pull apart a spareaxle (tnx Aaron):-
Wheel is attached to the axle firmly and has 2 pins sticking out, to engage the spurgear in 2 of the 6 holes on the gear.
If disengaged from the wheel, the gear itself is free to spin on the axle, it doesn’t grip the axle at all.
October 30, 2002 at 9:03 pm #16386
cheers for that one
