Bit Lar-g MONSTER TRUCK!!!
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Bit Lar-g MONSTER TRUCK!!!
- This topic has 12 replies, 2 voices, and was last updated 23 years, 5 months ago by
May 20, 2002 at 8:23 pm #8957
Announcing the BIT LAR-G. Yes, that?s right. A Monster Truck Bit Char-g.
I went to Toy?s R Us and found a truck with wheels the size I wanted (they were actually made by Tonka) and started on the modification. I started with the back. I took the wheels and gear off the original axle and decided the axle was too short for clearance with the frame of the bit. So I hunted for a piece of metal with .048″ Diameter. I searched through paper clips, wire whisks in the kitchen and finally found a safety pin to fit exactly. This was a great find since a safety pin is much harder and won?t bend. I slid and glued the gear on. Drilled out the wheels to fit snugly over the axle. I had to make spacers to fit over the axle and in between the body and wheel to move the wheel out away from the body for clearance. I glued the spacers and wheels on and I was done with the back wheels.
Now the fronts are a lot trickier since they spin on the axle. I found some nails that were .070″ diameter and drilled the front wheels with a .075″ hole so they would spin freely on the axle. The head of the nail is on the outside of the wheel holding it just like the original wheels. Then I measured how much spacer I wanted and added the thickness of the steering knuckle (white piece of the bit that the axle presses in) and cut my axles that long. Now the tricky part. The axle is too big to press in the knuckle so I put the head end of the nail in a drill and took a cut off wheel with my dremel and hacked some lines in the part of the axle that was to be pressed in the knuckle until it was down to .053″ diameter. Be careful, I had to try this a few times to get it right. If you go down to .050″ it will fall out. So, I take the axle, put on the wheel, put on the spacer and push it in the knuckle. All done, just need to reassemble the front steering and I?m done.
Well, now, of course, the body won?t fit so I raise it up and use hot glue to hold it between the wheels along the side. (can?t see the glue since it?s up inside the body) and now I?m really done.
OK, now for the test ride. Of course it takes about twice as long to get up to speed but it was a lot peppier then I thought it would be. And finally, the steering actually works! Yes, it?s sluggish but it works great! I am so happy with this modification. Now I?ll have to build an off road coarse that regular bit?s can?t do that mine can.
Anyway, I wish I had a better camera. It turned out GREAT!
http://www.geocities.com/pfabersac/bitlarg.html
Custom “bit superchar-g” dual motor to come soon.
-Peter
May 20, 2002 at 10:03 pm #13739
WOW! You must have a LOT of time on your hands to do all this stuff.
Can I make a mod request? AWD bits
Then we can have some real fun with the WRX, Skyline,and EVO.
May 20, 2002 at 10:13 pm #13740
You are a Sick…sick dude.
God Bless Ya!
Awsome.
-Floyd
ps. Post a damn movie of it in action.
May 20, 2002 at 10:15 pm #13741
Yes, It took a lot of time and patients but it was worth it. It is soooo fund to drive. The tires are hard so it spins out well on hard floors but they have deep tread on them so theyclimb over rope or pens if you have built up speed.
I’ve thought about awd but it would be quite dificult to make front wheel steering and drive that small. The carhas a hard enough timesteering now. Iimagine with an axle up front it wouldn’t steer at all. I’m sure it could be done but, wow, what a job.
-Peter
May 21, 2002 at 1:51 am #13765
My friend is buying a digital camera soon, probablynext week. I’ll take a movie of it in action and post it ASAP.
-Peter
May 21, 2002 at 7:00 am #13778
Make’s my T-Maxx look like a waste of $400!
Great Job! :smiley14:
May 21, 2002 at 7:16 am #13780
OMG! That is one of THE best mods I’ve seen yet!
FANTASTIC WORK, Prabbit. Please hit me with some photos (and videos when ready) and I’ll create a special gallery page to pay homage to your creation!
Derek
May 21, 2002 at 6:50 pm #13789
Will do. My friend has a better camera so I’ll get him to take some good pics and send them to you. The video may take a week or so.
-Peter
May 21, 2002 at 10:35 pm #13809
You should show us how you did that, I want one!
May 22, 2002 at 2:58 am #13848
Just follow my directions up top. I would post lengths and sizes but the lengths of the axles will differ depending on the wheels you find. You just have to find the wheels and make the truck from those dimensions.
It sure is fun to drive. It runs a lot better on the tile now since it dosn’t jump at ever grout line. It also looks likea real moster truck when you turn because the front wheels almost touch the back ones! Really cool. I’ll be getting a friend with a digital camera that takes movies to film it Friday. Hope to get it to you guys soon.
-Peter
By the way, I took my WRX body off it and put on my Lancer Bullet body.
May 23, 2002 at 2:08 am #13929
YES!!! I have a video of my Bit Lar-g in action. Check it out
Go to
http://www.geocities.com/pfabersac/BitDigi.html
AndClick on “Bit Lar-g MONSTER TRUCK Video”
Yipppppeeee!
May 23, 2002 at 9:43 pm #14000
Do you think this mod could be easier if you just glued the backside of the bigger wheels to the outside of the original bit wheels?Anybody think this would work?
Also, I was thinking you could use some double sided tape, a small square piece of foam, and some velcro to raise the body. Tape the foam to the PC board cover and use the velcro to attach the body to the foam. Makes it easier to switch bodies than hot glue.
May 23, 2002 at 10:56 pm #14008
Great idea on the body velcro. I was going to do something similar to that but I broke one of the tabs off of my PC board cover so it wasn’t as strong as I’d like.
Glue the backside onto the original wheels? GREAT IDEA. I wish I would have thought of that! I just might try that
-Peter
