Bit Racer Axles
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Discussion › Bit Racer Axles
- This topic has 8 replies, 3 voices, and was last updated 23 years ago by
t00l.
November 10, 2002 at 4:45 pm #9527
Okay i want to make areally fast bit and i want to use bit racer gears. Anybody know where i can get some?
November 11, 2002 at 1:12 am #17298
*cough* mini-zone.dinball.com *cough* or just dinball.com *cough* hope this helps:smiley2:
November 11, 2002 at 5:47 am #17311
Jamie,
i tried that with the dark green gears from a MPH/KPH set. It doesn’t work to well. I think it is becuase the bit charge weighs twice as much as the KIT racer, so motor just doesn’t have the torque to get it going properly. Anyway, good luck with your mod, I hope it works better than my attempt.the ratios
November 11, 2002 at 7:13 am #17319Quote:Originally posted by jamiekulhanek on 10November2002
Tomy Bit Racer = Hot Wheels K.I.T Racer; they’re easily available at your nearest KMart/Target etc. Found them at every 1 I’ve been to in the last 3 weeks, car kits are A$24.
January 3, 2003 at 12:41 pm #17381
i have bit racer axles, now all i need is a triple cell bit or a dual cell becos right now evn my 3.5 turns them like a 1.0 speed
January 3, 2003 at 9:56 pm #17409Quote:Originally posted by Dr_Yo on 11November2002
I think you need some cough medicine!!
January 7, 2003 at 8:25 am #17601
Yeah there dog slow. My tri cell mod with dual motors should do the trick.
January 7, 2003 at 1:14 pm #17625
tri cell:smiley3:, cant wait for my tri cell booster;), im gonna blow you away jamie
January 7, 2003 at 3:45 pm #17644
tri cell :O, i thought dual cell was heaps
that would be like 20min charges?
you can get the gear kits from toyeast.com very cheap if you import
found them very good
