Bit stopped working after vehicle collision
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Bit stopped working after vehicle collision
- This topic has 10 replies, 6 voices, and was last updated 22 years, 8 months ago by
Crom.
January 19, 2003 at 10:17 am #10128
while test driving my son’s Bit on our nearly finished track, I failed to negotiate a turn and slammed head on into a wall. The vehicle stopped working. The wheels don’t funtion nor do the rear wheels. The vehicle does work while it’s on the controller in the charging position. What could be wrong, and what can I do to fix it?
Thank you much
January 19, 2003 at 2:48 pm #43008
Does the car work when you hold it in different orientations? Like upside down or vertically?
You might have knocked the battery slightly out of it’s socket.
Try looking under the circuit board in the car. The battery is the green cyclinder lying horizontally in the rear of the chassis. Just make sure that it is still seated properly.
For pictures showing how to dissassemble the car, look at
http://www.ausmicro.com/technical/bitcharg/front-end-disassembly-how-to/index.htmBe careful when you open up the car, there are some very thin and fragile wires inside.
January 20, 2003 at 1:21 am #42994
Yep, If it runs ok on the charger it sounds like a battery to me
:smiley16:uA -
January 20, 2003 at 4:52 pm #42980
yep same here, check the battery = ) i had that problem, car only ran on the charger, means the battery isnt in position
57MHZ 2.6 Booster Trueno
January 21, 2003 at 2:51 pm #42876Quote:Yep, If it runs ok on the charger it sounds like a battery to me
:smiley16:uADoes that mean that when you charge up the bit, the Rx has to deal with the voltages that you’re supplying?
Uh oh…
January 21, 2003 at 8:36 pm #42864
Yep thats true, but there is a 3 volt zener diode on the Rx pcb that limits the voltage going into the board to 3V.(The small pinky coloured glass component) So you are safe to charge at 4.5 or 6 volts. I dont know what voltage it would take to burn out the zener, but when it does you will hear a little bang and see a little smoke…….
Then it will be Uh oh !!!! 😯
:smiley16:uA
January 22, 2003 at 2:30 pm #42828
hehe .. UH OH :shy:
January 22, 2003 at 2:58 pm #42820
Well, no uh oh’s… 🙂 yet… 😀 But I’m beginning to think I should just shell out the $10 to JNH and get a spare 27MHz chassis just in case.
July 7, 2003 at 11:53 am #24447
Why did this tutorial vanish? Where is it now? Does anybody know?
July 7, 2003 at 2:34 pm #24390
WHAT YOU CAN GET SPARE CHASSIS’S?
July 8, 2003 at 7:41 pm #24254
wouldnt mind another booster chassis, hint: trading direct! BOOSTER CHASSIS!!!
