Bizarre Watersports ;)
Home › Forums › Floating & Flying – Discussion › Bizarre Watersports ;)
- This topic has 22 replies, 7 voices, and was last updated 21 years, 8 months ago by
July 2, 2004 at 4:52 am #12233
Over the last few weeks I have developed a hankerin for an RC boat. This is weird, because generally, not a huge water fan. With a budget of ~au$50 where should I start? Micro with mods… Bigger with mods, or crazy large and pretty much stock. Is proportionality (is this a real word?) that important, or will an icecream container with a tinracer board slapped in it be as much fun? It will prolly sit in it s box 95% of the time and the rest will be spent being driven (captained?) by me and my mates while drunk and camping. Any tips OTP/jamie/boat-heads?
July 2, 2004 at 3:40 pm #53087
Well, i’ve never seen an R/C icecream bucket!!
$50 is fairly low budget for a boat, my boat is using recycled gear, with about $75 extra stuff, so the final price for the complete thing would be around $220.
an icecream bucket probably wouldnt steer very well at all, and would have too much drag….i hope you were joking when you said that anyway….
Proportional ain’t that important, many boats have a one speed only throttle…..its not like you can break traction and spin a boat out!!
Propo steering obviously has its benefits…..you could roll a boat at full throttle if you only have non propo steering.
One rule of thumb i go by is….don’t use your r/c when you are drunk…..usually your out somewhere when getting hammered and the R/Cs stay home.
With your budget in mind…..go for a mini or micro boat.
July 2, 2004 at 7:47 pm #53096Quote:Proportional ain’t that important, many boats have a one speed only throttle…..its not like you can break traction and spin a boat out!!
Actually, you can spin a boat. 1:1 tunnel hulls (some times refered to as Formula 1 powerboats) do so a lot. It’s mostly a result of too much steering rather than too much throttle though. But, yes, many of the most powerful R/C boats use no more than an on/off switch for throttle because it’s a lot cheaper than a 28cell ESC.
You really have to tell us what kind of boat you want (ship, scale, sailing, racing etc), where you wish to use it, and go from there.
If you check out my VACII on my site, I’ve only spent $10 so far. The Arno XI plans will be made available at WGu once the model is tested. There may even be a prize for the best interpretation 😉
July 2, 2004 at 8:43 pm #53097Quote:Actually, you can spin a boat. 1:1 tunnel hulls (some times refered to as Formula 1 powerboats) do so a lot. It’s mostly a result of too much steering rather than too much throttle though.
What i meant was if you had steering that was non propo (full lock or nothing) and non propo throttle (full noise or nothing) spinning a boat would probably happen alot more.
Listen to OTP, hes the boat man.
July 3, 2004 at 5:34 am #53113
I guess what i am after is the tinracer of boats. Idiot-proof, tinker-able, and cheap.
July 3, 2004 at 9:26 pm #53115
hey, about the bout. my friend made a boat shaped like a catamaran from bolser wodd with surfboard foam for floats. he has 2 plane motors with propellors on the back for power and to steer, he has a servo that conects a switch to either of the motors. so to turn right, the left motor turns of and the right one turns on. his boat is faster than any of the “real” boats at our nearest club and it was only a fraction of the cost
July 3, 2004 at 9:34 pm #53116
LEARN TO SPELL BUDDY
Edited by – merc-blue on 03 July 2004 17:41:43
July 3, 2004 at 9:35 pm #53117
this can’t go without comment!
bout
bolser
wodd
propellor
conect
of=
boat
balsa
wood
propeller
connect
offfer christ’s sake man!! there are too many ways to edit these messages!! learn howda spell real good!:8ball:
July 3, 2004 at 9:46 pm #53118
my eyes hurt trying to read these posts :question:
i know you guys got stuff to say but really what the hell are you trying to say?
btw look up ebay there are a whole heap of cheap rc boats which dont look half bad.
cheapest ive seen are these and there easy to use maybe even to hop up
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=2564&item=5907437884&rd=1
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=2564&item=5906463921&rd=1
that pic is from the first boat look at the room inside that bad boy heaps of potential to put bigger motors and better electronics
July 3, 2004 at 9:49 pm #53119
yeh they are 380 size motors it looks like.. you can get brushless at that size … HEHEHEHE
July 3, 2004 at 11:47 pm #53124
hey man. not my fault i’m stupid
July 3, 2004 at 11:50 pm #53125
i just suck at tryin to type fast
July 3, 2004 at 11:57 pm #53127
Have you got Tin racer electronics handy? If you can build a balsa structure yourself, then it should cost practically nothing. Otherwise look in the toy section for non-R/C plastic boats that can be modded. There are heaps out there, I haven’t bought any myself because none meet my scale/ realism criteria, and if I have to do more than a tiny bit of re-working, may as well start from scratch.
July 4, 2004 at 3:41 am #53135
ill_race_ya, i’m guessing you are a 12 y.o. kid, right??
Try S L O W I N G down when you type.
Balsa wood is very cheap, and fairly easy to work with (you have probably used it more than me!)
I’m not sure what glue is the best to use.
I’ve hade good results with CA, balsa cement is a tad weak.
July 4, 2004 at 3:43 am #53137
yeh get a good CA .. like FLASH i use either thin or med. depending on the jub thin is great but need a micro droper and very steady hands and ur peaices have to be cut really well
July 4, 2004 at 3:51 am #53140
we need an interpreter for this topic:8ball:
July 4, 2004 at 5:22 am #53146
My next big warship is going to be mostly built with PVA glue.
July 4, 2004 at 5:30 am #53147
Oh yes, PVA is bloody strong stuff……
but I was thinking that water or moisture might weaken it as I believe it is water based……OTP slap me if i’m wrong…
July 4, 2004 at 7:22 am #53148
As long as you paint your boat and let it dry after a days sailing, it’s fine. Wouldn’t use it on a 1:1 boat, but for our perposes it’s strong, non toxic and easy to work with.
Apparently you can get waterproof PVA now.
July 4, 2004 at 1:46 pm #53154
aw, u think i’m twelve. dammit.i’m 15 and i’m actually in top english classes so i’m not that stupid
July 5, 2004 at 7:22 pm #53193
WTF what school do u goto??
July 5, 2004 at 11:41 pm #53201
Ghetto High?
Any way, I think I have killed the knock off of Trent’s tank I was building, so that can go on hold and i can throw my self at this project.
I was thinking of a basic paddle-steamer maybe, either direct drive or using a tamiya twin motor gearbox, to run the paddles. -
July 6, 2004 at 2:37 am #53202
i like the paddle steamer idea! you can even put one of those mini foggers in it!:8ball:
