Boat Rudder
Home › Forums › Floating & Flying – Discussion › Boat Rudder
- This topic has 3 replies, 3 voices, and was last updated 20 years, 4 months ago by
jamiekulhanek.
September 30, 2004 at 3:05 pm #12361
Hi all,
I m making a boat from the guts of a bit charg and need some sort of rudder system. Actuator coils won t work due to the forces involved and I don t want to use 2 engines to steer, so does anyone have any ideas on this ? -
September 30, 2004 at 7:22 pm #55829
Yep,make an airboat,then u can use rudder or twin motors ! You should be able to make a rudder work using a gear/lever setup to get your actuator coil to turn a rudder.It would require less force(on the actuator) to make it work if levered..I made one from a rc can car and it worked fine in the mates pool.Stretch a balloon over your rx stuff and seal with silicon,perfect waterproofin !! mmmmmm I might try makin a sub !! Hell,another idea to drive me crazy…
October 1, 2004 at 4:51 pm #55866
Thanks Cavo, but I don’t really want an air-boat – and this thing is going to have a Speed400 motor in it, so not really for the pool 🙂
June 19, 2005 at 6:46 am #59647Quote:vbthanks wrote:
Thanks Cavo, but I don”t really want an air-boat – and this thing is going to have a Speed400 motor in it, so not really for the pool 🙂
OK…your barking up the wrong tree. For a speed 400, a BCG board will be an instant failure. Even a mini Z board will not suffice.
I guarantee it..
CanI please see pics of the boat? Boats are actually very tricky to get running right, I hope to point u in the right direction.
The cheapest solution I have found is what I’m doing.
Reciever/ESC module:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJRV3&P=7
Servo:
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXTX41&P=ML
This will work with any 27mhz AM R/C transmitter, except BCG ones!
