Hi Graham – and welcome to the MicroForum
Battery life, range etc is much of a muchness. If anything – the running time is EXTENDED with a boosted car.Thecircuiton board the car is simply a3ch (instead of 2ch) to allowboost. Without the boostbutton depressed thecircuit pulses power to the rearwheels (hundreds pf times per second), instead of supplying a constant 1.2v. That’s how you get slightly better battery life!
When the turbo button is pressed down, the car behaves like a “normal” Char-G and screams off into the distance. The big benefit that you will pick up from the Booster car is when racing on a circuit.Leave the turbo button off around the curvey sections of the track and then punch it it for the faster sections of the track. It just offers you so much more control.
Hope that helps
Derek
