broken car
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › broken car
- This topic has 26 replies, 12 voices, and was last updated 22 years, 10 months ago by
ekwj.
April 8, 2003 at 7:00 am #10195
Helloooo everyone. ok I;m new to bit char-g and i have a problem with one of my cars If i press the forward or backward button on the remote the wheels go backwards the steering is fine (i think).I have taken the pcb off and there is one of the fine wires off but i’m not sure which blob of solder it came from. it is a brand new car but it was sold as seen so i cant take it back. Just wondered if anyone was in the know about repairs and how to fix the problem. is it the car or the remote.? thanks jord
jord
April 8, 2003 at 6:18 pm #34552
so you’re saying when you press forward it goes backwards, and when you press backwards it goes forwards?
if so, you’ve mixed a pcb with the remote, so it’s the combo, to fix it, you could reverse the forward and reverse wires on the pcb.betta recognize… uh huh 🙂
April 8, 2003 at 6:35 pm #34556
or the battery is on backwards
The sky is the limit! |ekR34|
April 8, 2003 at 11:30 pm #34570
that wouldnt make a differnece ^ if the battery is in backwards the car wouldnt run becos the terminals would be reversed and wouldnt be giving any power.
April 9, 2003 at 12:55 am #34571
No if i press forwards it goes backwards and if i press backwards it goes backwards. steering seems ok
jord
April 9, 2003 at 2:00 am #34573
hmmm. then the wires arent connected correctly, have a look under the PCB
April 9, 2003 at 2:06 am #34574
if it’s ok I’ll post a closeup picture and hopefully you can say whats wrong. I’ll post it anyway. lol
jord
April 9, 2003 at 3:31 am #34577
definetaly sounds like the wires, maybe a short.
http://bitpimps.lixlink.com -
April 9, 2003 at 4:40 pm #34541
yeah a pic would help alot dude.. cos right now its just guess work by us all
April 10, 2003 at 5:29 am #34530
i used to have a tamiya 4wd mini racer and had the batteries placed backwards.. and when i turned it on it went backwards.. LoL… it most prolly is a different case for the bit char-g..
April 10, 2003 at 10:06 pm #34509Quote:i used to have a tamiya 4wd mini racer and had the batteries placed backwards.. and when i turned it on it went backwards.. LoL… it most prolly is a different case for the bit char-g..
Yes; there’s more ‘smarts’ in the BCG. 🙂
Mini4X4 can run in either direction, but get the battery wrong way in a BCG and you’ll fry the electronics.
April 10, 2003 at 10:08 pm #34510Quote:I have taken the pcb off and there is one of the fine wires off but i’m not sure which blob of solder it came from. it is a brand new car but it was sold as seen so i cant take it back. Just wondered if anyone was in the know about repairs and how to fix the problem. is it the car or the remote.?
Is this a TOMY car in the first place?
There are 4 solder pads that relate to the 4 wires that go to the 2 coils, and motor. Just need to look carefully to see which one its off.
April 10, 2003 at 11:43 pm #34513
Fry the electronics? better becareful when installing batteries then or you’d waste a $40++ worth toy 🙂
April 11, 2003 at 5:21 pm #34468
they arent toys they are interests lol
April 11, 2003 at 7:57 pm #34473
More like a way of life, pimpin life……:smiley2:
April 12, 2003 at 7:15 pm #34413
hehe let’s face it shypo… bcg’s are toys and theres nothing we can do about it! 🙂
April 14, 2003 at 2:29 am #34393
I will never admit to that…..they’re not a toy…they’re not, they’re not :angry:
April 14, 2003 at 4:15 am #39740
so it isn’t.. it’s just something that kids play with 🙂
April 14, 2003 at 10:38 pm #34294
no not kids. most of the people on this site are 16 or older… i dont think they would be defined as kids.
April 15, 2003 at 1:01 am #34237
welll… we are like the 50% of people who own bcg’s the other 50% are kids… (that’s what i think i may be wrong) there’s just no way that a kid would say no to a bcg.. i mean.. it’s too cool to not want one! 🙂
April 17, 2003 at 10:18 am #33861
OK i think we should wrap this one up now I soldered the wire back on and the steering works again but the car still only goes backwards so it is going to the bit graveyard in my bitbox.
Thanks for all the suggestions on how to fix it but its a hopeless case.Good job i only paid ?5 for it not ?30. thanks everyone.:approve:
jord
April 25, 2003 at 9:21 am #39680Quote:welll… we are like the 50% of people who own bcg’s the other 50% are kids…
Uhm, I don’t think so.
Here in Europe and in Italy there are a lot of “mature” player, definitely not kids.
But they are not toys, they are little rc models… when you take it to a racing tracks they are not more a toy but they are a rc model.
Your acts are the key here, if you play with it like a toy, well it is a toy. Otherwise they are not (think about modification, special circuits, tuning and organized racing…)Ciao
Efarel -
April 26, 2003 at 11:45 am #32960
If it goes backward when you press forward and backward when you press backward then you could have one of two problem. Most likely you have a bad transisitor on the PC board in your car. The transistors are the little black cube things that line up with the solder points. The Transistors are just used as switches (or more like relays). The steering only uses one transistor per direction since there’s just one coil per direction but the motor is different since it reverses polarity for forward vs. backward. I think there are 3 transnstors involved in forward/backward motion. I’d say it’s probably one of those transistors. The only fix is to replace the bad transistor but most likely you don’t have a transistor laying around. If you want to know how to test them just let me know. If you have another parts car you can swap PC boards.
The other, less likely problem would be in the remote. It’s possible the buttons in the remote are broken allowing it to press the reverse swithc even when pressing forward on the plastic rocker. Open up the remote and pull out the rocker switches and see if the little studs that it pivots on are broken.
-Peter
April 27, 2003 at 4:46 am #32859
Let’s just say that BCGs are a Hobby. For kids under 10, they are probebly a toy. But I am sure that there are alot of people under 16 that make BCG as one of their hobbies. Like me, I am only 15. And I’ve been play around with Model Crafts since Grade 3. I use to own a RC helicopter, something like 10 or more Mini 4WD Racers. I won one of the Mini 4WD Regional Championship back in China. So it is all depends on how u treat this BCG staff. If u just buy it and play with it, then it’s not a hoppy. But if u bought it and do all sorts of mods; collect different shells, then it’s one of your hobbies. And most of the kids won’t make it as one of their hoppies yet because this BCG staff does cost alot of money. So i think it is for people between 8-80 years old.
Let’s do 1/4 Mile under 8 Seconds!!!
April 27, 2003 at 6:40 pm #39274
i would say its more 12-60, because i doubt that a parent of an 8 year old would let them solder things and modify little tiny things with little tiny parts. Also an 80 year old person wont even understand what the thing is, let alone be able to take apart the circuits. I wouldnt even think a 60 year old person would have one but you never know!!!:p
you are currently at: http://www.ausmicro.com
April 27, 2003 at 10:55 pm #32792
Do we have any 60 year olds, Hmmmmm, cmon fess up.:smiley2:
April 28, 2003 at 3:40 pm #32666
easy, do a poll about preferred motors. anyone who preferes the 1.0 has got to be old.
