Charging problem
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › Charging problem
- This topic has 4 replies, 3 voices, and was last updated 23 years ago by
PandaBear.
October 22, 2002 at 3:57 pm #9378
Hi, i’m having a problem with the charger on my bit. It worked initially but now it wont.
When I clip the car onto the remote, the light comes on for a fraction of a second then goes off. The car definately doesn’t charge after the light goes off. If I quickly put the car on and off over and over again the car will charge a little.
I have tried brand new batteries checked the connections to the charger and checked the battery in the car. The only thing Ican think of is a dead charging timer. Anyone got any ideas what might cause this?
Thanks in advance
Chris
October 22, 2002 at 4:30 pm #15809
Well try another car. If this doesnt help try replacing the components in the charging circuit.
There is a thread in technical that says what to replace, and schematics are available on the web.
I do hope you know what im talking about
October 22, 2002 at 6:48 pm #15819
Hi, I can’t find the thread saying what to replace anywhere!I have resoldered all of the components on the controller with no difference at all 🙁
October 23, 2002 at 6:38 am #15836
Take the bit(ch) back to where u bought it!
October 23, 2002 at 10:04 am #15847Quote:Originally posted by snakeman65 on 22October2002
There is nothing in the charging circuit that can ‘die’ just like that. (This is a genuine BCG, right?)
If there was anything that could be suspect, try changing the 2 transistors maybe.
Make sure also you haven’t broken the wires to the side terminals. Its too easy to do, I mucked mine up accidentally too and had to go dig out the solder iron.
