charging times
Home › Forums › Bit Char-G, Digi-Q and other Micros › Bit CharG and Micro Radio Controlled – Technical › charging times
- This topic has 8 replies, 4 voices, and was last updated 22 years, 1 month ago by
titaniumonkey.
October 29, 2003 at 7:51 pm #11878
I was thinking…since charging once with the stock charger on the remote won t fill it up(the battery in the car), how many times should I actually recharge to fill up the litle battery inside? BTW, the battery in the car is stock and no mods have been done to the car whatsoever. (don t wanna wreck it)
October 29, 2003 at 7:55 pm #47648
well if its tomy (50mah) then I would say 6-7 times I keep charging till the battery gets warm
Edited by – VooDooMafia on 29 October 2003 14:55:49
October 29, 2003 at 8:45 pm #47649
thanks for the quick reply. Wouldn’t that sorta mean 4.5 minutes???? that’s so long!
October 29, 2003 at 9:34 pm #47651
yea around there, like I said I just wait till the cell is warm(you can feel teh bottom of the chassie feels warm).
I realy gotta invest in one of them peak chargers
October 29, 2003 at 11:59 pm #47656
Sounds about right tite, then it should last about 10 minutes of run time.
October 30, 2003 at 4:48 pm #47674
well, on my new Fairlady chassis:D, I got about 20+ minutes of running time…is this normal? cuz I assumed it would be normal for it to run that long.
October 30, 2003 at 5:53 pm #47679
Off one charge? If I put mine on the charger 3-4 times yes you should get about 20 mins or so
October 30, 2003 at 6:09 pm #47681
The newer the batteries in the TX, the longer the run time, and the more torque the motor seems to have, especially with Energizers I’ve noticed, though I remember reading that one model of Energizers should be avoided because they put out more than the standard amout of power for a AAA. no idea how much truth there was in that though.
Replacement battery for in the car sells for around $5, so enjoy a little overcharging I say, just don’t let the battery get hot!
October 31, 2003 at 4:34 pm #47706
I have another battery that I got off of a clon (110mah!!!) anyways, no, I charged it about 5 times to get 20+ mins of runnung and I tried today a double charge and that went over 15 min of run time.
